A/C cycle switch install question/problem :( #1445501
05/31/13 11:51 AM
05/31/13 11:51 AM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
On my '85 Ram, the factory A/C cycle switch's sensor/probe is installed in it's own sheath built into the pressure line going from the compressor to the evaporator.
I want to install a new one but cannot get the probe out! I've soaked it 4 days with PB, pulled on it, clamped vice grips on it and tapped with a hammer....the lil' *ukka ain't moving.
Can I 5 minute epoxy the new cycle switch's probe to the metal part of the pressure line and wrap/insulate it with body dum-dum and expect it to work properly?
Your thoughts/opinions/advice, please.
Re: A/C cycle switch install question/problem :( [Re: rnch] #1445502
05/31/13 04:00 PM
05/31/13 04:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I wouldn't epoxy it, just lay the capillary alongside the line and hold it in place with some of that "tar tape" that's used to stop A/C lines from sweating.
That's how the cycling switches that replace the EPR valve are done.
Re: A/C cycle switch install question/problem :( [Re: John_Kunkel] #1445503
06/01/13 08:44 PM
06/01/13 08:44 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
UPDATE: Well, I managed to break the probe, trying to pull it out of the pressure line sheath.
Now the A/C clutch won't engage...on one of the hottest & most humid days this year here in New Orleans!
I seldom drive the truck more than 40 minutes at a time. Can I jump out the cycling switch until the new one arrives?
If so, how do I go about doing this??
