1980 Power Wagon Front Axle #1444395
05/29/13 06:56 PM
05/29/13 06:56 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I just replaced my front leaf springs. While I had the front end off the ground I was able to spin both front wheels without the other moving at all. Is that normal. I have the Dana 44. I know that on rear diffs that if you have sure grip both turn in one direction and if you have open the other wheels turns in opposite direction. This is my first 4x4 and wasn't sure if a front differential acts the same as a rear one.
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: 1980 Power Wagon Front Axle [Re: Texas383] #1444396
05/29/13 07:14 PM
05/29/13 07:14 PM
scratchnfotraction Offline
does it have locking hubs? if so only the wheel will turn and not the axles/diff.
lock the hubs and turn them again both off the ground.
looks like you have lock out hubs in the pic of your truck.
Re: 1980 Power Wagon Front Axle [Re: Texas383] #1444397
05/29/13 07:16 PM
05/29/13 07:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you have the hubs locked in and if so are you sure they were engaging? If so did you see the pinion yoke turn?
Re: 1980 Power Wagon Front Axle [Re: scratchnfotraction] #1444398
05/29/13 07:18 PM
05/29/13 07:18 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
also if it has a vacuum 4x4 activation same symptom...bob
Re: 1980 Power Wagon Front Axle [Re: savoy64] #1444399
05/29/13 07:24 PM
05/29/13 07:24 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
80 in Non cad and Lockout
Re: 1980 Power Wagon Front Axle [Re: Texas383] #1444400
05/30/13 01:53 AM
05/30/13 01:53 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, the big 3 all regained their senses and put manual locking hubs on the whole lineup for model year 1980. Well at least 1/2 ton through 3/4 tons for sure. There may have been some H.D. 1 tons with that bolt on cap deal on fronts, not sure. Their next screw up was the auto-lock hubs.
Re: 1980 Power Wagon Front Axle [Re: buildanother] #1444401
05/30/13 03:23 AM
05/30/13 03:23 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
All the D60s had the his stick out even on full time setups just no lockouts. Lockouts can be added.
Re: 1980 Power Wagon Front Axle [Re: 76dodgeboy] #1444402
05/30/13 04:49 AM
05/30/13 04:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Even with lockouts locked or full time with an open carrier the wheels will spin untill the trans caes is locked...
I am truckless..
Re: 1980 Power Wagon Front Axle [Re: Texas383] #1444403
05/30/13 11:38 AM
05/30/13 11:38 AM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I have locking hubs.... and the hubs were free when I was spinning the wheels. I had my head up my butt and wasn't taking that into consideration. Next time I have it off the ground I'll check it with it locked.
1969 Y2 Super Bee
