Big block First Gen Dakota - What oil pan? #1443671
05/28/13 02:29 PM
05/28/13 02:29 PM
MA
Greg55_99 Offline OP
MA
For those that have dropped a 440 into a Dak, what oil pan is used? Modified stock? Pics?
Greg
Re: Big block First Gen Dakota - What oil pan? [Re: Greg55_99] #1443672
05/28/13 04:21 PM
05/28/13 04:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Big block First Gen Dakota - What oil pan? [Re: 340SHORTY] #1443673
05/28/13 05:52 PM
05/28/13 05:52 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Id assume a regular truck pan should work. That's a bit much for an oil pan
Re: Big block First Gen Dakota - What oil pan? [Re: 76dodgeboy] #1443674
05/28/13 07:45 PM
05/28/13 07:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Nope.. The X member and rack n pinion interfere with the front of the normal truck rear sump pan .
Even the SB pan for the V8 Shelby trucks of this vintage was unique to the truck..
I was in with Schumacher on the R&D on this subject and also the conversion engine mounts.
I am truckless..
Re: Big block First Gen Dakota - What oil pan? [Re: 340SHORTY] #1443675
05/28/13 08:18 PM
05/28/13 08:18 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
No experience on the Gen 1 or 2 trucks, but gen 3 has the rack in the front of the crossmember. I put a 383 in my 98 and used a stock rear sump truck pan. Fit great with no problems
**Photobucket sucks**
Re: Big block First Gen Dakota - What oil pan? [Re: 340SHORTY] #1443676
05/28/13 10:43 PM
05/28/13 10:43 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just ask Katfish He had a Bigblock in his. First I've heard of needing a different oil pan for the swap. Even for a sb. If that's the case Id just raise the motor to clear
Re: Big block First Gen Dakota - What oil pan? [Re: 76dodgeboy] #1443677
05/30/13 09:36 PM
05/30/13 09:36 PM
ky.
K
kenworth_goose Offline
K
ky.
I done a couple of these swaps. I move engine , trans back 2.5 inches and use stock truck pans. Solves a whole lot of problems and gets a bunch of weight off the nose. Just notice how far the engine sets away from the firewall on stock dakotas.
Re: Big block First Gen Dakota - What oil pan? [Re: kenworth_goose] #1443678
05/30/13 10:22 PM
05/30/13 10:22 PM
NW Indiana
W
WeeWillie Offline
WeeWillie  Offline
W
NW Indiana
Sorry for the hi-jack, have you found an off-the-shelf header to fit with the engine now moved back? Did you use a motor plate or fab up your own mounts? Thanks in advance.
Re: Big block First Gen Dakota - What oil pan? [Re: WeeWillie] #1443679
05/31/13 11:57 PM
05/31/13 11:57 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the sump area on a dakota oil pan is about 1/2 the size of a regular truck oil pan---for a small block just find the correct oil pan and pick up tube----for a bigblock you need to be a fabricator or know how to find one---either for the oilpan or cutting the firewall and tunnel for clearance....bob
Re: Big block First Gen Dakota - What oil pan? [Re: savoy64] #1443680
06/01/13 12:59 AM
06/01/13 12:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Did you read the above post? No pan fable needed
Re: Big block First Gen Dakota - What oil pan? [Re: WeeWillie] #1443681
06/01/13 11:10 PM
06/01/13 11:10 PM
ky.
K
K
ky.
I fab truck brackets welded to the frame, then bolt in with factory engine brackets and mounts. I keep it simple. On the small block stuff you can use dakota headers. On the big block stuff you can use engine swap headers. There no need for high dollar schumacher engine swap kits. The first one I did took me an hour to figure out and weld the brackets.
Re: Big block First Gen Dakota - What oil pan? [Re: savoy64] #1443682
06/01/13 11:13 PM
06/01/13 11:13 PM
ky.
K
K
ky.
There is zero need to cut the firewall on either the smaal or big block swap! Plenty of clearance to slide engine, trans. back 2.5 inches on both without ANY major mods.
