440 Six Pack won't run for crap
#1443472
05/28/13 01:26 PM
05/28/13 01:26 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
I am having issues with the 500 inch 6 pack motor I have in my charger. It is a fresh build and I can not get it to idle below 1000 as we are bottomed out on the idle adjustment at that level. I do not have an idle solenoid hooked up just yet as it is on order but would that help with idle speed or just run on? I put a vaccum gauge on it and it has between 9-11 of vaccum at idle. The car seems very very sluggish and does not seem to pull hard at all. If I roll it out in first and hit it around 10 mph it will give a quick bog and them go but not like it should for the build. I have set the fuel levels, adjusted idle mixture and the timing is set at 6 initial and then the vaccum is hooked up to advance( I know it is a little lower level but that is so it does not run on when shut off as we had issues with that at any higher level). Anyone have any ideas? It seems very flat and will almost die when it idles down to turn a corner. I have not checked the powervalve but I have a 5.5 ordered to swap out. Here are the engine specs: 500 inch 9.6 comp stealth heads comp cams .564 lift duration 251 intake 257 exhaust @.50 1 3/4 headers brand new remanufactured carbs stock aluminum 69.5 intake auto with 2800 stall 3.55 gears power brakes Any help needed!!
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: 440 Six Pack won't run for crap
[Re: vette1986]
#1443479
05/28/13 05:27 PM
05/28/13 05:27 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Mine is 496" with 6 pak and with a big Comp solid, I have 16*-17* initial with a REAL quick curve...all in by 2200 RPM. No vacuum advance hooked up and running 36* total timing.I ran the Comp XE295Hl before and it should tie into it like gangbusters when set up right. Check your end carbs to make sure they are not open too far with the throttle at rest....the rods should JUST pop into the throttle levers on the end carbs. And make sure you don't have a vacuum leak at the intake.....I've had that happen before when the paper gaskets I put on the intake pan moved when installing. Late timing down low will cause a bog.
would you think the vaccum should be more with this cam than 9-11? that seems low to me and I am wondering if I am losing it somewhere. I guess I will shoot some starter fluid around the intake to see if that detects it unless you guys have any other method for locating a vaccum leak. THanks
That sounds right ....I think mine was around 10 or so.....it's the high idle that you'll have to chase down too...is the PCV port on the center carb being used or have you got it capped off?? Like mentioned, high idle usually means too much air (vacuum leak). Is the center carb's throttle plates closing all the way??? If they are remaned carbs, I'd check that too. 38* is maybe a tad high for a stroker engine....mine falls off after 36*.
[Re: superwrench]
#1443480
05/28/13 05:33 PM
05/28/13 05:33 PM
Posts: 5,155 CT
GTX MATT
CT
I would only expect around 10 inches of vacuum with that cam in a 440. Even though you've got more cubes at idle it won't matter much. Needs more timing but that is going to exacerbate your fast idle issue. Are you setting up the center carb with the outboards disconnected?
[Re: GTX MATT]
#1443481
05/28/13 05:40 PM
05/28/13 05:40 PM
superwrench
100%.....you have to find what's causing the high idle first.....that thing will not idle at all with the screw backed all the way out if everything is right. Keep us posted....
[Re: sogtx]
#1443484
05/28/13 05:57 PM
05/28/13 05:57 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
oy vey -- you cant just bolt this stuff on ..
are all carb bolts tight with an inch/lb wrench 160 i belive ?
something makin it idle faster - usually more air .
read this
https://board.moparts.org/ubbthreads/show...rue#Post7349675
actually mine worked very well out of the box w/ very little tweaking. I have since added more compression muuuch better heads and a solid roller cam.. that's when the tweaking started.
[Re: Mr.Yuck]
#1443485
05/28/13 06:03 PM
05/28/13 06:03 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
read this
The OP has a 500 inch engine , they carbs are calibrated for something that is 60 cubes less , so tweaking is a given ...
[Re: JohnRR]
#1443486
05/28/13 06:14 PM
05/28/13 06:14 PM
Mr.Yuck
Brookeville, Md
read this
yup before he bolted them on he should have upped the squirter, upped the jets, maybe dropped to the purple springs and went w/ a 4.5PV...
[Re: Mr.Yuck]
#1443490
05/28/13 07:55 PM
05/28/13 07:55 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Not today-Not on a stroker Is this for an a12 car ? I know youve been shopping For one .. Sorry John didnt see your reply .. Quote:
read this
[url=https://board.moparts.org/ubbthreads/showflat.php?
Cat=0&Board=Racer&Number=7349675&Searchpage=2&Main=7346119&Words=Tom_Quad&topic=&Search=true#Post7349675]https://board.moparts.org/ubbthreads/show...rue#Post7349675[/url]
[Re: jlatessa]
#1443491
05/28/13 08:09 PM
05/28/13 08:09 PM
superwrench
I agree with a timing change BEFORE touching anything else.
Joe
Why is it idling SO fast at 6* of initial?? It shouldn't idle at all with the base screw not touching....I'm not doubting anything anyone has said so far, but a high idle with the screw backed off is a point of concern....
That is a pretty lumpy cam in there...I've had one....I still say find the idle woes and go from there...
And again I'm presuming the OP has the screw backed right off.
