Page 4 of 5 1 2 3 4 5
Re: 1941 Dodge truck project [Re: Flipper1938] #1443151
08/28/14 10:52 PM
08/28/14 10:52 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
looks like it sets pretty nice Richard.
are you going to close up the wheel opening?
thats what we did with the big truck fenders we used.
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443152
08/29/14 11:03 PM
08/29/14 11:03 PM
Kentucky
Flipper1938 Offline OP
Kentucky
Yep, they are gonna get closed in. Maybe not quite 1/2 ton tight though.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443153
08/30/14 10:02 PM
08/30/14 10:02 PM
Mopar Ron Offline
Mopar Ron  Offline
Re: 1941 Dodge truck project [Re: Flipper1938] #1443154
09/29/14 10:37 AM
09/29/14 10:37 AM
Kentucky
Kentucky
I hit the swap meet at Delta River Cruisin' at Samstown Casino in Tunica, MS and found this. A bumper identified as a 51 chevy ? rear bumper with a $40 price tag. I knew it wasn't chevy, and thought it might be raw material for a Fargo bumper. I ended up talking the guy down to $15. I'm pretty sure it originally came on the front of a mid-50's Studebaker Hawk!
10644799_657969614310597_5175288417884343316_n by Flipper_1938, on Flickr
10432086_657969744310584_8563848775849235485_n by Flipper_1938, on Flickr
10685372_657969727643919_7385515686478459670_n by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1443155
09/29/14 09:30 PM
09/29/14 09:30 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
This is my favorite part of a build when you can buy parts on the cheap. My front bumper was $25 with brackets.
Re: 1941 Dodge truck project [Re: Flipper1938] #1830528
05/20/15 01:12 AM
05/20/15 01:12 AM
Kentucky
Kentucky
I haven't done much recently, but I'm gonna get back on it...
Re: 1941 Dodge truck project [Re: Flipper1938] #1834281
05/26/15 12:42 AM
05/26/15 12:42 AM
Kentucky
Kentucky
Finally got around to trying the camaro exhaust manifolds...I like 'em way better than the truck manifolds. There will be lots more room for passengers feet.
20150523_092759 by Flipper_1938, on Flickr
20150523_094717 by Flipper_1938, on Flickr
20150523_100553 by Flipper_1938, on Flickr
Started mocking stuff up. Seat is a mystery bench that came with the dodge. column is a mystery column too.
20150523_171940 by Flipper_1938, on Flickr
20150523_172406 by Flipper_1938, on Flickr
20150523_172444 by Flipper_1938, on Flickr
not a clue....
20150523_172541 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1834282
05/26/15 12:44 AM
05/26/15 12:44 AM
Kentucky
Kentucky
I can't believe they didn't center the gauges to the steering wheel.
20150523_181921 by Flipper_1938, on Flickr
lots of set-back
20150523_192040 by Flipper_1938, on Flickr
I actually did something!
20150525_103112 by Flipper_1938, on Flickr
I welded in the tubes for the middle body mounts (I'm doing 6 for the cab)
20150524_154353 by Flipper_1938, on Flickr
Then welded in a crossbar at the rear of the door opening that will be two more body mount locations.
20150525_140547 by Flipper_1938, on Flickr
Since I'm no longer doing the dropped down floor thing, I think I'm going to put some tube in the rocker area to make the front body mounts easier to attach
20150525_140620 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1834285
05/26/15 12:48 AM
05/26/15 12:48 AM
Kentucky
Kentucky
Anybody know if the steering wheel and column are Dodge/Plymouth/Fargo?
20150525_115746 by Flipper_1938, on Flickr
20150525_115728 by Flipper_1938, on Flickr
20150525_115716 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1834399
05/26/15 10:42 AM
05/26/15 10:42 AM
moparx Offline
moparx  Offline
the coil attached to the bottom of the column is interesting.
beer
Re: 1941 Dodge truck project [Re: Flipper1938] #1834643
05/26/15 04:48 PM
05/26/15 04:48 PM
Kentucky
Kentucky
Anybody think it might be from a WC54 military ambulance? I think we had the column from one of those stashed in the barn.
Re: 1941 Dodge truck project [Re: Flipper1938] #1840397
06/03/15 12:09 PM
06/03/15 12:09 PM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Originally Posted By Flipper1938
I gave up on trying to find a cheap stand alone efi set-up for a dodge and crossed over to the dark side. I bought a 5.3 LS motor/trans/ecm and harness/gas tank/driveshaft for $900. Chevy computers are apparently way easier to crack (people will remove the anti-theft/emissions stuff and re-flash for $75) and instructions to modify the harness are online.
IMG_6248 by Flipper_1938, on Flickr
UGH!
Re: 1941 Dodge truck project [Re: Flipper1938] #1843582
06/07/15 06:31 PM
06/07/15 06:31 PM
Kentucky
Kentucky
I'm using a late model motor (2001) but I still want it to look like a hot rod. I just know there is a tunnel ram hiding in that plastic truck intake.
....kinda funky cutting/welding on plastic
Before
IMG_7119 by Flipper_1938, on Flickr
first round of cuts. Getting rid of the guides for the wiring harness and the mounting bosses for the engine cover cleans things up a bunch
IMG_7122 by Flipper_1938, on Flickr
No turning back now....
IMG_7124 by Flipper_1938, on Flickr
I'm leaving the functional stuff where it is....I thought about shaving everything, but I still plan on running the stock ugly fuel rails (I don't want the rails to stand out any more than they do now). I'm shooting for something that looks like it could be OEM...just prettier.
IMG_7125 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1843666
06/07/15 08:51 PM
06/07/15 08:51 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Maybe swap to an Edelbrock intake?
I run one on my LS in my Torana, and aside from better mid range and upper RPM power, it does look pretty cool too I'd say.
(I moved the coil packs as well off the valve covers and inbetween the intake runners)
Re: 1941 Dodge truck project [Re: OzHemi] #1843685
06/07/15 09:07 PM
06/07/15 09:07 PM
Kentucky
Kentucky
I'd love to run the Edelbrock....my wallet won't let me. I'm trying to make the stocker look a little like yours
Re: 1941 Dodge truck project [Re: Flipper1938] #1843692
06/07/15 09:13 PM
06/07/15 09:13 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I bought mine when they had first come out (Saw it at SEMA and ordered one as soon as Summit had got them in stock) and it wasn't all that bad a price really..
Especially compared to other LS intakes at the time! Holley does a really tall style one now as well I have seen.. but been really happy with the Edelbrock.
Not a lot of car people seem to run them from the height though is all..I have a factory rear facing/cowl scoop on my car though so have the room under that.
Re: 1941 Dodge truck project [Re: OzHemi] #1843760
06/07/15 10:20 PM
06/07/15 10:20 PM
85086
Lil Herman
Lil Herman
85086
Here's what my buddy does to dress them up. up
Re: 1941 Dodge truck project [Re: Flipper1938] #1843765
06/07/15 10:24 PM
06/07/15 10:24 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Obviously eating blueberries doesn't help you have steady hands when it comes to taking pics. nervous tonguue
Re: 1941 Dodge truck project [Re: OzHemi] #1843803
06/07/15 10:57 PM
06/07/15 10:57 PM
85086
Lil Herman
Lil Herman
85086
We had an earthquake that day. shruggy
Re: 1941 Dodge truck project [Re: Flipper1938] #1843816
06/07/15 11:04 PM
06/07/15 11:04 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
work
