Boost crowd, who's using water/methanol injection? #144266
11/01/08 02:56 PM
11/01/08 02:56 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
Which kit are you using for water injection? Also, are you using boost juice, washer solvent, or mixing your own? I've been looking at Snow Performance, because the one at the supercharger store is almost 800 bucks!
Re: Boost crowd, who's using water/methanol injection? [Re: todd440] #144267
11/01/08 03:01 PM
11/01/08 03:01 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Spearco here (NOS stuff) .... works great ...is metered THREE ways ..... and is a HE!! of alot less than 800 beans !
Re: Boost crowd, who's using water/methanol injection? [Re: todd440] #144268
11/01/08 03:02 PM
11/01/08 03:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I was going to use Snow on my next S/C application. Plus w/ meth/H2) no need for an inner-cooler
Re: Boost crowd, who's using water/methanol injection? [Re: Mr.Yuck] #144269
11/01/08 05:47 PM
11/01/08 05:47 PM
I use an old Varijection that I modified a bit for instant on under boost. I spray 50/50 isopropyl and water (less corrosive) onto the turbine inlet. Works great, I have been running it for over 20 years on the TT340.
I don't agree with the statement that water injection will negate the need or usefullness of an intercooler. They do some similar things, like cool the charge air, but the water and alcohol also displace air and can impede fuel vaporization. The best setup is to have just enough of the water injection to allow higher compression and boost levels, and do the rest of the cooling with an intercooler. I actually use very little water and probably don't go through 2 gallons a year in normal cruising with occasional romps.
Re: Boost crowd, who's using water/methanol injection? [Re: todd440] #144270
11/02/08 12:22 PM
11/02/08 12:22 PM
Mr440GSS Offline
Mr440GSS  Offline
I am using the Supercharger Store kit with just regular window wash. Seems to work good, although , I don't have anything else to compare it to.
