Re: TCI aluminum deep pan leaking - Part 2
[Re: gpuller]
#1442532
05/27/13 02:20 AM
05/27/13 02:20 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
That will be the next gasket I'll use if this one leaks again after I find a way to keep the bolts tight. I got a fel-pro gasket, a new one again, and put the high tack gasket sealer on all four surfaces. Let it dry to a tacky touch. Installed pan. Didn't put any fluid in for over 24 hours. Ran the car a few miles, got home, no leakes, and checked the bolts. They were ever so slightly loose. Tightened them again. Drove a few miles today, got home and pan was leaking. Bolts were loose again. Tightened them again! Drove a few miles again, got home no leaks. Checked bolts, they were loose again!! About maybe an 1/8 of a turn to tighten them except two that took about a 1/4 turn to tighten them. Don't know why the bolts keep coming loose so I want to try the Blue Threadlocker. Hopefully that will keep the bolts tight and the pan from leaking.
[Re: Junky]
#1442533
05/27/13 02:23 AM
05/27/13 02:23 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
P/N 2464324AC
that should be the only gasket you use...and they are reusable too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Junky]
#1442534
05/27/13 08:21 AM
05/27/13 08:21 AM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
Are you positive its the pan leaking? I only ask because I thought my cast pan wasn't sealing only to find out it was my dipstick tube o ring. I needed to install a new o ring with some rtv smeared on it to stop the leak. Shift seals are also another potential leak source that makes it look like its a pan leak.
[Re: 70AARcuda]
#1442536
05/27/13 11:58 AM
05/27/13 11:58 AM
Posts: 1,630 North Central Florida
eightlitermopar
I also had a TCI pan that I finally got to seal. I soon found out I had a bad casting and it was leaking THROUGH the pan. 1 little pinhole. I returned that pan, got another, used the gasket mentioned and used lock-washers on the bolts. That seemed to do it. eightlitermopar
Mopar or no car
[Re: 70AARcuda]
#1442538
05/27/13 12:50 PM
05/27/13 12:50 PM
Junky
Wherever I am.
P/N 2464324AC
If the Blue Threadlocker doesn't work keeping the pan bolts tight, I'll be trying that gasket for sure.
[Re: dOc !]
#1442540
05/27/13 02:58 PM
05/27/13 02:58 PM
Junky
Wherever I am.
How loose are the bolts in the treads of the trans case ?.... OTHER THAN getting some of those nylon inserted bolts(they have been used on some of the B/RB and Hemi engine oil pans) .... I would try a simple lite lock washer....
Sorry, Doc, I don't understand what you are trying to tell me.
The bolts for the pan have lock washers.
The trans is fine.
No plastic anywhere.
[Re: Junky]
#1442542
05/27/13 05:04 PM
05/27/13 05:04 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
The trans is fine.
JUNKster ... show us a pic of those bolts. You have never seen those ny-lock bolts ?
[Re: dOc !]
#1442546
05/27/13 06:38 PM
05/27/13 06:38 PM
MPerry
Mopahts memba'
Mopahts memba'
mBerri ....I would worry about pulling the threads OUT OF the trans case ....
Pulling with blue locktite???
[Re: dOc !]
#1442547
05/27/13 11:28 PM
05/27/13 11:28 PM
Junky
Wherever I am.
The trans is fine.
Doc, never seen those before.
Would those work better than the bolts that came with the pan and Permatex Blue Threadlock, Locktite, Locktight? That one.
[Re: hp383]
#1442552
05/28/13 01:43 AM
05/28/13 01:43 AM
Junky
Wherever I am.
Come on??? Do pan bolts really come loose or does the gasket shrink and the bolts need tightening? I would tighten and paint mark them and drive it. My bets are junk gaskets or a leak from somewhere else.
Thats what I was wondering. As the gasket compresses, then seats, it will cause the bolts to loosen up.
They do the same thing on valve cover gaskets, and hose clamps.
If I knew the answer I'd not ask the question.
I know for a fact that when changing trans fluid using the stock steel pan this doesn't happen. But with this aluminum pan the bolts need re-torquing every time I get home from taking the car out and about.
There's nothing leaking from the transmission, only from the gasket area when the bolts loosen up. I'm not making this stuff up. I'm frustrated and sick of messing with it. I'm about ready to go back to a steel pan.
BTW, it's a Fel-pro gasket.
[Re: NITROUSN]
#1442555
05/28/13 11:19 AM
05/28/13 11:19 AM
Junky
Wherever I am.
Go to a Mopar dealer and get a factory gasket.
Is this factory gasket going to work on a non factory aluminum pan?
[Re: scratchnfotraction]
#1442559
05/29/13 07:56 PM
05/29/13 07:56 PM
Junky
Wherever I am.
remember....longer bolts and do not over torque them.
that gasket will not compress. just that o-ring bead compresses.
Thanks, Scratchn.
[Re: gpuller]
#1442560
05/29/13 07:57 PM
05/29/13 07:57 PM
Junky
Wherever I am.
That gasket is the cats ass, wont smash from over tightening. Use some new bolts and lock washers. When I posted that price that was from a few years ago. Figured it had to go up in price some.
I figured so. I posted it just in case someone wanted to know.
[Re: Junky]
#1442561
05/29/13 08:12 PM
05/29/13 08:12 PM
Posts: 5,304 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
On my Duster...I have a M.P. STEEL deep pan with the factory rigid gasket that the dealers sell. No more leaks from the pan... Shift shaft seal, that's next on the to do list!
Plymouth Makes It!
