Swapping front rotors to change bolt pattern, bearings? #1441965
05/25/13 10:30 PM
05/25/13 10:30 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I'm swapping a 1982 9 1/4 axle with the small bolt pattern into my 1985 D-150, I am also swapping the front rotors from the 82 to the 85 so the bolt pattern will be the same on all 4 corners, my question is, do I need to just buy the inner front wheel bearing and race for a 82 to swap the rotor assembly to my 85 , or do I need inners and outers, I wold think the outers would be the same, or am I missing something?. The small bolt pattern hub/rotor assemblies are in perfect shape, I just want to make sure I have all the right parts on hand before I start the swap. Thanks!!
Re: Swapping front rotors to change bolt pattern, bearings? [Re: tt76400] #1441966
05/25/13 10:38 PM
05/25/13 10:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just use 85 rotors. same bearings
Re: Swapping front rotors to change bolt pattern, bearings? [Re: 76dodgeboy] #1441967
05/25/13 11:53 PM
05/25/13 11:53 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I'm putting the 82 rotors on my 85 truck to get the small bolt pattern to match the rear
Re: Swapping front rotors to change bolt pattern, bearings? [Re: tt76400] #1441968
05/26/13 12:45 AM
05/26/13 12:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Same differance. Use early 80s to get small bolt or 85-93 to get big bolt. They use the same bearings. Just put the 82 rotors on after repacking the bearings
Re: Swapping front rotors to change bolt pattern, bearings? [Re: 76dodgeboy] #1441969
05/26/13 09:37 AM
05/26/13 09:37 AM
scratchnfotraction Offline
same bearing for the early/late trucks.
76 new yoker rotors fit the trucks for the SBP with same bearing also.
I have orderd the 76 NYs cheaper than 82 truck rotors for some reason each time i have swaped a set. so you may want to shop around on price.
Re: Swapping front rotors to change bolt pattern, bearings? [Re: scratchnfotraction] #1441970
05/26/13 08:54 PM
05/26/13 08:54 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I agree scratch. I have used 77 New Yorker rotors before.iirc, they are a tad bigger diameter, but they work fine.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
