72-80 Leaf spring swap, m880 springs
#1440116
05/21/13 10:45 PM
05/21/13 10:45 PM
Posts: 572 Portland , Oregon, United Stat...
smokes
I am wondering if '77 Dodge m880 leaf springs are physically the same dimensions as my '78 half ton springs. My 1/2 ton leaf springs do not cut it for any sort of weight in the bed so I figured I would swap on some more heavy duty springs. I went to the wrecking yard and found a '77 m880 with a full suspension on it. I am taking the leaf springs, blocks and u bolts and leaf spring eyelet bolts. I just was double checking to make sure they are physically the same dimensions and will work on my truck? I know that the u bolts/ blocks may be different heights which is why i got them. Eventually I will get the 3/4 ton dana axles but for now I will be just replacing the springs. Any thoughts?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: 72-80 Leaf spring swap, m880 springs
[Re: smokes]
#1440120
05/21/13 11:10 PM
05/21/13 11:10 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The rears were all I had access to for the rears. The fronts will work also.. I add a Rear hi arc rear main leaf with the ends cut off to my front rc springs. The ride was firmer but not drasticly rough..
I am truckless..
[Re: hp383]
#1440127
05/29/13 04:44 PM
05/29/13 04:44 PM
smokes
Any one know if the u bolts and the plates are the same? I grabbed them all but just want to know if I need to clean the 3/4 ton ones up or if I can use my 1/2 ton ones that are clean.
[Re: 76dodgeboy]
#1440129
05/29/13 11:49 PM
05/29/13 11:49 PM
Posts: 2,094 central texas
krautrock
central texas
the m880 is probably just a heavier rated rear leaf...as in there were probably a few different weight ratings available back then.
the front springs need to be stiffer IMO. my truck rides and drives much better after putting stiffer springs in the front.
[Re: 76dodgeboy]
#1440135
05/31/13 02:16 PM
05/31/13 02:16 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
If you want a taller block, use one from a 91-93 Dodge diesel club cab 4x4 they used a factory 6" block, the rest were 4" or 5" i dont recall.
And there are some reports, and pictures, of factory 3" blocks on some models of trucks. I'm not sure what decided the block height on the trucks, it seems to be a mystery.
My Ramcharger has a diesel lift block in the rear, and I used an add-a-leaf to the front to level it out. Sits perfect and easily clears 33" tires on 9x17 wheels.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1440136
05/31/13 02:47 PM
05/31/13 02:47 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
[Re: 76dodgeboy]
#1440137
05/31/13 04:15 PM
05/31/13 04:15 PM
krautrock
central texas
yeah the block on my m880 is like 3" or maybe 3.5" i forget exactly. mine does have a pretty aggressive rake with factory springs all around.
my truck has the factory rearend in it, dana60, so the axle tubes/spring perches might make the height of a 1/2 ton truck a little less than on an actual m880.
i still think you'll end up with some rake, it'll be fine though. get the rear together then decide what you want to do with the front.
btw there should be a metal plate on the dash in the m880 that list the weight ratings and all that stuff.
[Re: NITROUSN]
#1440139
06/01/13 10:31 AM
06/01/13 10:31 AM
krautrock
central texas
if you use the m880 block
There is no M880 block. A Special M880 is just a camo fart.
i used that term to describe the block that should be on the m880 he's pulling the suspension parts from (because it's possible his truck might have a different block, who know...)
i didn't imply that the m880 has a "special" block or anything
