DANA 44 ?????? #1439698
05/20/13 11:44 PM
05/20/13 11:44 PM
East Texas
Mopar2DBone Offline OP
East Texas
How can I tell if my Dana 44 is a 3500lb or a 4500lb???? 1979 W200 360 cid Thanks...
Re: DANA 44 ?????? [Re: Mopar2DBone] #1439699
05/20/13 11:56 PM
05/20/13 11:56 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It won't be a 44 @ 4500#s
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439700
05/20/13 11:58 PM
05/20/13 11:58 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Also your door sticker will give axle ratings
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439701
05/21/13 12:00 AM
05/21/13 12:00 AM
East Texas
East Texas
The Chrysler dealer parts book shows 2 Dana 44's.. A 3500 and 4500 Rockauto.com also list 2 different ones... So what gives??? Thanks..
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439702
05/21/13 12:01 AM
05/21/13 12:01 AM
East Texas
East Texas
Now were talking.. I'll check that out.. Thanks..
Re: DANA 44 ?????? [Re: Mopar2DBone] #1439703
05/21/13 12:06 AM
05/21/13 12:06 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Maybe they did? I've never heard of such beast. I just know themes the half ton and D44hd which is 3/4 ton. Its possible that's the difference also. Did rockauto specify 5 or 8 lug?
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439704
05/21/13 12:15 AM
05/21/13 12:15 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What are you looking for?
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439705
05/21/13 12:16 AM
05/21/13 12:16 AM
East Texas
East Texas
No but it says the 4500 is part time 4x4.. So I guess that's locking hubs.. The door sticker says 1476 kgs and that translates in about 3200 lbs. so I guess its a 3500 lb axle... Thanks for your help...
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439706
05/21/13 12:19 AM
05/21/13 12:19 AM
East Texas
East Texas
Driveshaft and outer axle shafts...
Re: DANA 44 ?????? [Re: Mopar2DBone] #1439707
05/21/13 12:43 AM
05/21/13 12:43 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Front drive shaft?
Re: DANA 44 ?????? [Re: Mopar2DBone] #1439708
05/21/13 12:45 AM
05/21/13 12:45 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I believe the 4500# axle is the part time 8 lug axle. Thats whats on my 73 W200. Mine also has bigger lugs than a full time 8 lug 44.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439709
05/21/13 01:58 AM
05/21/13 01:58 AM
East Texas
East Texas
Front drive shaft?
Yes....
Re: DANA 44 ?????? [Re: Mopar2DBone] #1439710
05/21/13 02:06 AM
05/21/13 02:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
No locking hubs on 79 w200's that I ever heard of. The lighter duty had the nut and cotter pin with 8 lugs, and the heavy duty had a bolt on cap deal IIRC.
Re: DANA 44 ?????? [Re: buildanother] #1439711
05/21/13 02:15 AM
05/21/13 02:15 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Up till 74 Had lockout do to having a part time transfercase. 75 went to fulltime and the Flat Non locking hubs up till 79. 80 they went back to part time.
I have a Front drive shaft. Pm me if interested
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439712
05/21/13 02:35 AM
05/21/13 02:35 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Bolt on cap means its a D60.
The 200 designates it an 8lug truck. 100/150 are 5lug anything 200 and over is 8lug.
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439713
05/21/13 02:56 AM
05/21/13 02:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Im pretty sure the 4500 is listed incorrect because the W300 Doesn't list the 3500# axle.
All Fulltime D44s share the Same front driveshaft 1/2 or 3/4 ton. The D60 is the diff one as its drive shaft needs to be smaller do to the bigger carrier area and the yoke sticking out further.
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439714
05/21/13 10:37 PM
05/21/13 10:37 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Right on. No Dana 44 4,500 pound axles. In 79 there were only 2 axles used in a w-200. 44 series which was 3,500 and sometimes called the 4,000 pound. The 4,500 was dana 60.
Re: DANA 44 ?????? [Re: NITROUSN] #1439715
05/21/13 10:42 PM
05/21/13 10:42 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That's what I figured. Especially after checking Rockauto myself. The W200 listing shows it listed as a D44. I knew it wasn't right when I checked the W300 and it had the same part number but didn't say D44. They also list with or without lockouts.
He's looking for an outer axle for a 200. Would a 150 work? I've heard the 150 is slightly wider
Re: DANA 44 ?????? [Re: 76dodgeboy] #1439716
05/21/13 11:20 PM
05/21/13 11:20 PM
N
N
The outer stubs were the same 44 on the 1/2 ton and LD 3/4 tons.
Re: DANA 44 ?????? [Re: NITROUSN] #1439717
05/22/13 12:02 AM
05/22/13 12:02 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Well if the outer axle shaft is the same Id have that along with the driveshaft if you didn't find one today
Thanks for the info Nitrousn. So the axle tubes are diff widths between 1/2 and 3/4?
