Page 3 of 3 1 2 3
Re: oil additive question [Re: 493_DART] #143902
11/08/08 08:11 AM
11/08/08 08:11 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
EOS is now available--they changed the part # . i think its also $20 a bottle
Only stuff to use at break in and regular oil changes.
Re: oil additive question [Re: DAMOPARS] #143903
11/08/08 01:03 PM
11/08/08 01:03 PM
"Here is VOA info I found on Royal Purple API (SL) Rated 5W-20 motor oil.
Zinc: 666ppm
Phosphorous: 563
CompSyn"
That looks more like an SM level than SL. I still wonder who else is playing those kind of games.
Re: oil additive question [Re: CompSyn] #143904
11/08/08 02:29 PM
11/08/08 02:29 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
In the last year I have found about 60 qts of left over older formula SJ and SL at various stores.
So tonite I was in a Walmart checking the back of the shelves. I noticed they carry Royal Purple, it has a SL rating. The Mobil 1 'High Mileage' oil also has a SL rating, not SM like other Mobil 1 formulas. Anyone know the Zn-Ph ppm of these two?
I prefer not to run diesel oil because of too much detergent and the racing oil has too little, requiring more frequent oil changes. Something I can get locally off the shelf would be great if High Mileage Mobil 1 has enough ZDDP.
The straight 30wt Castrol also has a SL rating, other 30wt oils I have seen in the past is still SL oil.
Mobil 1 10-40 High Mileage, SL/CF rated:
PHOSPHOROUS: 860
ZINC: 1035
I’ll keep looking for a up to date UOA/VOA for Royal Purple
CompSyn
Zinc: 666ppm
Phosphorous: 563
CompSyn
BTW, check out the New AMSOIL Group Discount for moparts.com members.
Thanks CompSyn .
The Mobil 1 HM doesn't look too bad, better than the other SM oils. Guess it would do in a jam but I'll find a local Amsoil dealer when my older SJ and SL oil supply is gone.
Royal Purple , appears they need to upgrade their labels to SM.
I keep seeing GM EOS has been re-released, only with another part #.
Whats the new # and is it still ZDDP or has it been changed to Moly?
Re: oil additive question [Re: B5 Bee] #143905
11/08/08 02:45 PM
11/08/08 02:45 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I found the new EOS.
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=EOS
I suspect it's not the same as it is labeled 'engine assembly lubricant'. Possibly it's Moly and not ZDDP. It's also twice the cost of what Hughes offers.
Re: oil additive question [Re: B5 Bee] #143906
11/08/08 07:25 PM
11/08/08 07:25 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Does it take just one bottle of the EOS per oil change?
Re: oil additive question [Re: B5 Bee] #143907
11/09/08 07:18 AM
11/09/08 07:18 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
PHOSPHOROUS: 860
ZINC: 1035
CompSyn
Zinc: 666ppm
Phosphorous: 563
CompSyn
Thanks CompSyn .
New GM EOS part # 88862586
This new stuff is listed as “engine assembly lubricant”.
Zinc: 4843ppm
Phosphorous: 5099ppm
Molybdenum: 4ppm
Calcium: 31320ppm
cSt Viscosity @ 100C: 22.09
CompSyn
Page 3 of 3 1 2 3
