radiator minimum?, diesel #1437838
05/17/13 12:42 AM
05/17/13 12:42 AM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Making an old heavy duty shop truck, using a 12v diesel in a 1951 ford f3 but I'm limited on radiator space. I need to use a double pass rad to get both inlets on same side. I was planning on using generic aftermarket rad so it'll be 19" tall w daul core 1" alumin tubes Id be better if I could get away w a 26" width but if I had to I could cut and fab space for 28", but that's the max I have room for. I will doing some towing and hauling w it but mainly car type weight. And oh ya I'll be running an electric fan(s).
Will 26" be enough, 28"? I'm not real experience w diesel a yet so not for sure. Opinions?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: radiator minimum?, diesel [Re: kilroy] #1437839
05/18/13 12:47 AM
05/18/13 12:47 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
kilroy---kind of in the same spot as you ----putting a 6bt into a 71 dodge truck---the 89-90 dodge diesel radiators are not all that big--i layed it flat and poured in 5.5 quarts---my possible radiator will be a 80 dodge truck aluminum aftermarket and it holds 1 gallon---having a custom made radiator will run around $500----my hot rod buddies buy circle track radiators from speedway for less than $200 to put into 30,s cars---if you check speedways catalog it will give you all the dimensions----bob
Re: radiator minimum?, diesel [Re: savoy64] #1437840
05/18/13 04:55 PM
05/18/13 04:55 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Here is the engine bay FYI.
Also you can find rad cheap on ebay like your circle tracks friends are using. I also have one in my charger and they work great! Just wondering what anyone thought about how small I could go. The rad will also have plenty of air flow to it.
Re: radiator minimum?, diesel [Re: kilroy] #1437841
05/18/13 05:43 PM
05/18/13 05:43 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
guys are running fj40 stock radiators in cummins 4bt setups no problem---- also the range rover 6bt setups run on the stock radiator---newer cars and trucks are running on thinner units because they cool better....bob
