Re: NOT COOL!!!
[Re: HotRodRailroader]
#1437068
05/15/13 08:37 PM
05/15/13 08:37 PM
moparpollack
Lil Herman
Lil Herman
85086
Cooling problems come from more than just radiators, what is the timing set at? Is it rich or lean? Maybe the water is running water too fast thru the radiator try running a thermostat. BTW Lodi apples are the bomb!
Re: NOT COOL!!!
[Re: moparpollack]
#1437069
05/15/13 08:43 PM
05/15/13 08:43 PM
Posts: 1,401 northeast ohio
hulmule
northeast ohio
you need to run some type of stat. helps slow the water down and gives it time to cool thru rad. the other thing I learned is you want the motor to run at a constant temp and with a stat it regulates that. You aren't running straight water are you?? that's a no no .
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: NOT COOL!!!
#1437071
05/15/13 08:55 PM
05/15/13 08:55 PM
RapidRobert
The stiff hoses makes me think possible slight combustion leak into the cooling system (head gasket). I'd highly suggest a stat but that's not what's causing the problem at hand
Re: NOT COOL!!!
[Re: RapidRobert]
#1437072
05/15/13 09:04 PM
05/15/13 09:04 PM
moparpollack
Lil Herman
Lil Herman
85086
I didn't want to tell him that.
Re: NOT COOL!!!
#1437074
05/15/13 11:05 PM
05/15/13 11:05 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
First thing we have to know is how hot is it??? What kind of gauge do you have on it? Are the hoses hard to squeeze after just a few minutes or when it's at operating temp? How old is the radiator? Is it the old clogged original or is it new? Sorry if I didn't see any of this information listed but we need ALL the facts to make a correct diagnosis instead of just spit-balling possible causes.Over heating to me is 230 degrees without coming down Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: NOT COOL!!!
[Re: fourgearsavoy]
#1437075
05/15/13 11:20 PM
05/15/13 11:20 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Can you take the car to a local radiator shop? They should have the gizmo that attaches to the radiator cap port, and will test for compression gasses in the coolant.
You may not be able to see the leak with a compression test.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: NOT COOL!!!
#1437081
05/24/13 09:55 PM
05/24/13 09:55 PM
RapidRobert
Are you having an issue with it hitting 205 or is it that when it gets hot enough to stall it happens to be at ~205? as 205 ain't terrible. Are you running gasahol (10% ethanol alcohol) which can act up at 205. plus alot of temp gauges are not dead on accurate. I would toss the restrictor & use a 180/185 stat & if the real problem is the stalling then we can attack that. More info please. & does it get to 205 & shut down or does it get ever cooler on the highway OR around town?
Re: NOT COOL!!!
#1437085
05/24/13 11:11 PM
05/24/13 11:11 PM
RapidRobert
My original 3 row core OE 65 dart SB rad sprung a leak & a tin of coarse ground pepper from the Quik Shop on the way home fixed it for a year! then it sprung another leak in another location so I bought an eBay Champion 2 row direct fit aluminum radiator & I had to redrill 1 mounting hole on one side & it cools good (nothing to brag about on a DD 318 though) & no leaks & was ~ $189 iirc including shipping. I'd by another Champion rad in a heartbeat
