2003 cummins fule injectors #1435620
05/13/13 03:26 AM
05/13/13 03:26 AM
glendale , Arizona usa
kb7obj Offline OP
kb7obj  Offline OP
I have an injector or injectors going bad. I would like to know if I need to do anything special to replace the injectors? I have 184k on the truck
Re: 2003 cummins fule injectors [Re: kb7obj] #1435621
05/13/13 08:39 AM
05/13/13 08:39 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
They are due. Especially when you consider we have no sulfer in the fuel and that is the lubrication. I run used engine oil as an additive...They can be a real pain to get out. I did not swap out my last set, but the mechanic that did said they are a pain to get them out if they are the originals. You will chit when you get the new ones in...Will run like a scoulded monkey...
Re: 2003 cummins fule injectors [Re: kb7obj] #1435622
05/13/13 11:19 AM
05/13/13 11:19 AM
Kansas
cascius Offline
cascius  Offline
Kansas
Pay very close attention to your crossover tubes. They are common for the tips getting mushroomed and not seating into the injector properly. When you put the injectors in you should seat the crossover tubes in the injector and put the nut that holds them in finger tight to line everything up before tightening down the injector.
Don't get carried away with the tiny nuts that hold the wiring to the coil packs on the injectors. They are very fragile, and one "oops" will cost you another injector. You'll need a small pry bar to pop them out of the head once the crossover tubes are out. Place it between the injector hold down and the cylinder head and they should pop right up. It does take some effort, but nothing major. Make sure all the copper washers that are on the tips come out with the old injectors and new ones go in with the new injectors. You'll have to remove all the exhaust rocker arms to get to one of the bolts on each injector. It would probably be a good idea to run your overhead while you have it opened up if it hasn't been done recently. This isn't a complicated job at all. Pay close attention to how you take it apart and it will fall back together.
Last but not least, don't waste your money on cheap injectors. It will cost you more in the long run. Find a reputable Bosch dealer to purchase them from. They run about $330 a piece. Stay as far away as you can from Pensacola Diesel, no matter how enticing their prices are. Their stuff is absolute junk.
Re: 2003 cummins fule injectors [Re: cascius] #1435623
05/13/13 06:26 PM
05/13/13 06:26 PM
kb7obj Offline OP
kb7obj  Offline OP
thank you for the information
