1996 Dakota LCA bushings
#1431172
05/06/13 10:03 AM
05/06/13 10:03 AM
Posts: 1,486 STL
cdstl
STL
I am going to need to replace the LCA bushings. I am not at home and don't have my Haines manual with me. The question is how do you take the tension off of the Torsion bar?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1996 Dakota LCA bushings
[Re: cdstl]
#1431173
05/06/13 10:48 AM
05/06/13 10:48 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
The bolt heads face down at you back at trans crossmember area. Probably rusted too. You can't miss the bolts, and can see the threaded upper parts too. (both are backed off by turning counter clock)
[Re: buildanother]
#1431176
05/06/13 11:14 PM
05/06/13 11:14 PM
Posts: 1,486 STL
cdstl
STL
It did have the recall UBJ. I will have to look at mine when I get home but the replacement UBJs look like the one in my E body.
