440 RB distributors , #1431140
05/06/13 09:51 AM
05/06/13 09:51 AM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
hi guys , noticed every where i've been looking the mopar performance electronic 440 RB distributor , that comes in the kit with the orange box etc , seems to be out of stock ,
but what i have seen from of places a direct replacement for the mopar preformance one ,
are all these made by the same company , if so who ? also what guts are inside for replacement parts etc ?
have a look at the below links
http://www.jegs.com/i/Accel/110/59300/10002/-1
http://www.jegs.com/i/JEGS-Performance-Products/555/40506/10002/-1
http://www.summitracing.com/parts/pro-66994/overview/make/dodge
http://www.summitracing.com/parts/sum-850005-1/overview/make/dodge
also there are a couple more FBO being another one ,
appreciate any info
Re: 440 RB distributors , [Re: A47] #1431141
05/06/13 10:08 AM
05/06/13 10:08 AM
I'd suggest finding the best initial with the dist you have so you can then shorten the slots while you have it apart to get 36 total (the dimention is in the archives) but go a bit less then creep up on it then grab a JY RB dist & take it apart & clean & lube it & set the lower shaft end play to .005" with 1/2" ID flat shims or washers from a hardware store or www.speedwaymotors.com has a kit for cheap. Add a shim down on the nub in the center where the clip goes to reduce the cam plate axial play. Toss the heavy spring with the elongated slot on one end & work on spring tension staying just under the pinging point at WOT then plug in vac adv & work with it (2 adjustments). This'll give you a far better setup than anything you can buy & shaft/bushing wear is negligible on electronic units & if the guts ain't all rusted out you have a perfect base to work with for far less money than ANY new item that is currently offered. . There is alot of gain to be had by dialing in the subsystems IN ORDER
Re: 440 RB distributors , [Re: RapidRobert] #1431142
05/06/13 11:51 AM
05/06/13 11:51 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Maybe it's me but I just do not see anything that resembles an answer to the actual question asked in this ????
Re: 440 RB distributors , [Re: A47] #1431143
05/06/13 11:57 AM
05/06/13 11:57 AM
U.S.S.A.
U.S.S.A.
amazon has it for a little cheaper.
http://www.amazon.com/ACCEL-59300-Performance-Replacement-Distributor/dp/B000JJLNEE
It looks a lot like a prestolite dual point , I can't find any shots of the inside ???
Re: 440 RB distributors , [Re: JohnRR] #1431144
05/06/13 12:16 PM
05/06/13 12:16 PM
Yeah it's just you . Double R you forgot to add anything that was relevant to his question which means that your post was even less valuable than mine & that's assuming mine was of no value. I would suggest that you go back & edit or delete your post! I had no doubt that someone would opinionate on the best choice of the selections he listed & my thoughts were simply an alternative option that has worked (very well) for me. I even qualitied it with the symbol. Every dist I've modded has provided a vast improvement over stock.
Re: 440 RB distributors , [Re: RapidRobert] #1431145
05/06/13 12:43 PM
05/06/13 12:43 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
You could better than the kit ditributor having advanced rebuild yours to your specs. He does a great job reasonably priced and had mine done two weeks from drop off.
Advanceddistributors.com
What was I thinking....
Re: 440 RB distributors , [Re: 72blubird] #1431146
05/06/13 01:24 PM
05/06/13 01:24 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks you for the quick replies guys , its been appreciated ,
at the minute my MP distributor is ok , recently had to change the magnetic pick up ( second one in 7 years), that left me dead in the water , well road !! that got me thinking . getting another electronic distributior , all set up & dialed in as a spare , magnetic pick up craps out again , swap distributor on side of the road type thing ,
so no where on the list of didtributors i posted the links to , does it say what parts / guts are in the distributors ,
also i keep seeing mopar preformance parts , on back order for a long time , & or never to be in stock , check out left side RB stamped steel rocker arms , is mopar making any new parts or when the stock goes thats it
anyways thanks again for the replies
Re: 440 RB distributors , [Re: A47] #1431147
05/06/13 02:16 PM
05/06/13 02:16 PM
cmansell Offline
cmansell  Offline
I think you can spell Fiat without Mopar Performance. That was another company.
Re: 440 RB distributors , [Re: cmansell] #1431148
05/06/13 02:52 PM
05/06/13 02:52 PM
dogdays Offline
dogdays  Offline
Well, now we have two RRs, at each other's throats. Boys, behave!
I have had ONE mag pickup go bad in around 400,000 miles. I have also had TWO point-style distributors that were unreliable because, as it turned, out, they were worn to the point that the cam had lateral movement and wouldn't open the points all the time. So fuuture posters, don't tell me points are more reliable.
OP, WHY don't you buy a spare mag pickup and keep it in the trunk? It weighs less, costs less, and the distributor on the RB is in the front where you can get at it.
If that doesn't work for you, then troll the 'bay and pick up an Accel or Mallory electronic distributor if you really want to have one in your trunk. I don't trust the off-brand knockoffs, which I'm sure have QC issues.
RapidR may not have answered the question but he brings up a really important point. Getting the ignition curve right is one of the best things you can do for any engine.
To further muddy the issue, I would suggest getting a NEW distributor by a name brand and getting the curve right on it. Then take your current distributor and use it for a spare.
R.
PS: The RB with stock heads usually makes best power at 38 degrees ignition lead.
Re: 440 RB distributors , [Re: RapidRobert] #1431149
05/06/13 03:26 PM
05/06/13 03:26 PM
U.S.S.A.
U.S.S.A.
No I stand by my replies , he asked a specific question and instead of answering it you TOLD him what he should do instead.
Don't feel bad though , that is the Moparts way
edit , Robert that is good advice on how to set up the archaic original non adjustable advance units , but the new units are so much easier to deal with especially with trial and error of what total advance one wants. The only reason to go thru all that is to keep a numbers correct unit on the engine, otherwise switching to the new unit, or something better, is a no brainer for those that have the money to do so.
Re: 440 RB distributors , [Re: JohnRR] #1431150
05/06/13 05:22 PM
05/06/13 05:22 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks for the imput , appreciated , all my plan was to have another distributor all dialed in ready to go , should another pick up fail sometime , much easier & quicker to change out a distributor on the side of the road , than dismantal one , once back home i can then fit a new pick up & keep that as a spare , that was the idea ,
Re: 440 RB distributors , [Re: A47] #1431151
05/06/13 06:34 PM
05/06/13 06:34 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
The second Jegs one listed is the closest one I see to a MP unit. It has full mechanical adjustments and the instructions recommend the MP advance kit so it uses the same keys and springs to adjust it.
The first Summit one is made by Proform, junk, there are no adjustments and the advance springs are completely different from the Mopar units, so the kits available don't work. I am done fighting with mine and going with the Jegs unit. I am not familiar with the other two.
Re: 440 RB distributors , [Re: T2R9] #1431152
05/06/13 06:43 PM
05/06/13 06:43 PM
dogdays Offline
dogdays  Offline
Hey, I'm surprised. No one said the latest magic word.....Firecore!
R.
Re: 440 RB distributors , [Re: dogdays] #1431153
05/06/13 07:26 PM
05/06/13 07:26 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Due to some issue I can not get any information on, the MP distributors are all discontinued now. Whether they come in a kit or separate, they are gone.
I believe mp intends to try and take care of the issue and possibly offer the parts later, when whatever the problem is gets ironed out.
Rich H.
Esse Quam Videri
Re: 440 RB distributors , [Re: T2R9] #1431154
05/06/13 10:50 PM
05/06/13 10:50 PM
U.S.S.A.
U.S.S.A.
Can you snap a picture of it ? I wonder if that jegs unit is made by Mallory like the current MP unit ?
If the OP has an original Hemi dual point I'll gladly trade my Mallory/Mp RB unit for it ...
Re: 440 RB distributors , [Re: JohnRR] #1431155
05/07/13 06:44 AM
05/07/13 06:44 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I will when it arrives.
Re: 440 RB distributors , [Re: T2R9] #1431156
05/07/13 10:21 AM
05/07/13 10:21 AM
U.S.S.A.
U.S.S.A.
Thanks , I thought you already had it .
Re: 440 RB distributors , [Re: JohnRR] #1431157
05/08/13 06:11 PM
05/08/13 06:11 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Here is the Jegs unit. Looks close to the Mallory ones.
Re: 440 RB distributors , [Re: T2R9] #1431158
05/08/13 06:12 PM
05/08/13 06:12 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Mechanical advance.
Re: 440 RB distributors , [Re: T2R9] #1431159
05/08/13 06:16 PM
05/08/13 06:16 PM
U.S.S.A.
U.S.S.A.
Yes looks very much like the mallory mopar unit .
Does a mopar cap fit it ?
