Page 1 of 3 1 2 3
4 link setups #1430961
05/05/13 11:57 PM
05/05/13 11:57 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
so im thinking about eliminating the leafs in my d100 and putting in a 4 link with coil overs. anyone else have a 4 link setup on their d series? im mostly going to drive it on the street. but plan on taking it to the drag strip from time to time. i was looking at the competition engineering 2017 and 2028 kits. im leaning towards the 2028. anyone have any other suggestions on a good kit to get?
Re: 4 link setups [Re: BBD150] #1430962
05/06/13 12:02 AM
05/06/13 12:02 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Alot of money for the occasional strip run
Re: 4 link setups [Re: BBD150] #1430963
05/06/13 12:26 AM
05/06/13 12:26 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
If it's going to be a daily driver or even close, I would stick with the leaves. If tire clearance is your concern, move the leaves inboard. A 15x14 or maybe 15x15 will go under there with no frame mods...just by moving the springs, and some tub work. Yes, a leaf spring truck can hook up.
Just my
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 4 link setups [Re: old_goat] #1430964
05/06/13 08:09 AM
05/06/13 08:09 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ladder bars, super simple and hooks in a car wash...4-links are a pain. Also, its likely a 4-link will have the coil overs protrude thru the bed...
Re: 4 link setups [Re: Dragula] #1430965
05/06/13 08:13 PM
05/06/13 08:13 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
your truck is one of my favorite d series trucks ive seen. did you eliminate the leafs? id love to see some more pictures of your setup. what brand coil overs did you use? did you buy a ladder bar kit or did you make it yourself?
im wanting to eliminate the leafs due to them being junk. plus im planning to lower
Re: 4 link setups [Re: BBD150] #1430966
05/06/13 11:49 PM
05/06/13 11:49 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You can also look at running ladder bars with leafs. There is a kit that allows the housing to "float" as needed to prevent binding with the leafs.
Pretty simple setup, and doesn't cost much if you can do the welding yourself.
http://www.jegs.com/i/Jegster/550/41013K/10002/-1
Re: 4 link setups [Re: hp383] #1430967
05/07/13 12:26 AM
05/07/13 12:26 AM
orange,tx
O
onebadstepside Offline
O
orange,tx
my vote is for ladder bars
Small blocks rule!!!!!
Re: 4 link setups [Re: onebadstepside] #1430968
05/07/13 01:14 AM
05/07/13 01:14 AM
US
BBD150 Offline OP
BBD150  Offline OP
US
thats a nice truck in your sig. any details on the lowering you did to it? i have 1 ton control arms to put on mine. yours is sitting about the height i want mine to sit.
im leaning that way. any suggestions on kits for the ladder bars and a kit for the coil overs? the leafs are going to get eliminated. like i said the ones on it now are junk and i dont want to pay to put another set on it. i dont see a point in buying ladder bars and putting leafs back on it.
http://www.summitracing.com/parts/cmb-15-0017/media/images
i was looking at this kit for coils. going to replace the shocks that it comes with eventually with air shocks.
Re: 4 link setups [Re: BBD150] #1430969
05/07/13 01:34 AM
05/07/13 01:34 AM
orange,tx
O
O
orange,tx
I used a aftermarket lower control arm..its not all that great(its about all that was out there 8yrs ago)..if I had to over again I would use the 1 ton arms...I used 32 bars and qa1 shocks for the rear
Re: 4 link setups [Re: onebadstepside] #1430970
05/07/13 01:36 AM
05/07/13 01:36 AM
orange,tx
O
O
orange,tx
another
Re: 4 link setups [Re: onebadstepside] #1430971
05/07/13 01:37 AM
05/07/13 01:37 AM
orange,tx
O
O
orange,tx
2
Re: 4 link setups [Re: onebadstepside] #1430972
05/07/13 01:38 AM
05/07/13 01:38 AM
orange,tx
O
O
orange,tx
3
Re: 4 link setups [Re: onebadstepside] #1430973
05/07/13 01:39 AM
05/07/13 01:39 AM
orange,tx
O
O
orange,tx
Re: 4 link setups [Re: onebadstepside] #1430974
05/07/13 01:44 AM
05/07/13 01:44 AM
orange,tx
O
O
orange,tx
Re: 4 link setups [Re: onebadstepside] #1430975
05/07/13 03:09 AM
05/07/13 03:09 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
A 4 bar system closely resembles a 4 link but is much more street friendly. Either way your going to have the replace the underbed gas tank with a fuel cell to make room unless you have a in cab tank.. .
http://artmorrison.com/rearsusp-kits.php
I am truckless..
Re: 4 link setups [Re: onebadstepside] #1430976
05/07/13 04:26 AM
05/07/13 04:26 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I wish that I could just lift the body of my Ramcharger off the frame so that I could fabricate a rear suspension as nice as that one. Unfortunately I can't do that with the Ramcharger and just to grind the heads off the rivets holding the rear spring hangers to the frame and then using the air chisel to punch them out was a major PITA. But I am having fun in my garage!!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 4 link setups [Re: BBD150] #1430977
05/07/13 07:47 AM
05/07/13 07:47 AM
Dragula Offline
Dragula  Offline
Just an aftermarket set-up. I do not recall what brand, but I will look under it. No leafs. Rides and drives better than my diesel and nothing protrudes thru the bed.
Re: 4 link setups [Re: Dragula] #1430978
05/07/13 09:28 PM
05/07/13 09:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Explain why a coil over would mount higher on a 4 link vs a ladder bar set up?
Re: 4 link setups [Re: 340SHORTY] #1430979
05/08/13 12:37 AM
05/08/13 12:37 AM
US
BBD150 Offline OP
BBD150  Offline OP
US
i plan on putting a fuel cell in it. so all that space is free. so is there any disadvantages to competition engineering parts? im debating between these
http://www.summitracing.com/parts/cmb-15-0017/overview/
http://www.jegs.com/i/Competition+Engineering/247/2006/10002/-1
or the street kit from artmorrison which runs about $720
if i order the CE kits i will weld most of it together.
Re: 4 link setups [Re: BBD150] #1430980
05/08/13 01:11 AM
05/08/13 01:11 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The so called street kits have 60' times all over the board in something that leaves hard Urethane is not as stiff as a hiem joint
How fast do you want to go? & how much street driving are you going to do?
I can tell you from past experience if you ride hiems on the street & you don't grease them regular your next launch may be into the next lane
You can run 10's with leaf springs cheap & lower it till the frame sits on the ground
Page 1 of 3 1 2 3
