Re: Drum brake problem driving me nuts!
[Re: 67DeLuxe]
#1430885
05/15/13 10:08 PM
05/15/13 10:08 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Are the shoes on correct?Small front large rear.Are the adjusters on the right sides? Even though they should always hang up.Did you as suggested pull the master away from the firewall a bit and see if they still drag?Did you replace the hardware?Rocky
Chrysler Firepower
[Re: RapidRobert]
#1430888
05/16/13 04:31 PM
05/16/13 04:31 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes if the piston in the master is not allowed to came all the way back, the brakes will hang up because the fluid cannot return to the master.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
