Are tubular A arms available for the 92 Dakota 2wd? #1430823
05/05/13 07:51 PM
05/05/13 07:51 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Looking for a set of tubular arms for the 92 Dak.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Are tubular A arms available for the 92 Dakota 2wd? [Re: hp383] #1430824
05/05/13 10:30 PM
05/05/13 10:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not that Im aware of. Why do you want tubular?
Re: Are tubular A arms available for the 92 Dakota 2wd? [Re: 76dodgeboy] #1430825
05/05/13 11:27 PM
05/05/13 11:27 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Why not?
If I decide to replace all the bushings and ball joints it would be a good time to upgrade if they don't cost an arm & leg.
The upper a arm bushings are getting bad. So just trying to plan ahead.
Re: Are tubular A arms available for the 92 Dakota 2wd? [Re: hp383] #1430826
05/05/13 11:40 PM
05/05/13 11:40 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Looks like tubular arms for that year Dakota are going to be a custom made deal from a suspension/chassis shop. There do not appear to be any readily available. You can find poly bushings for the OEM arms.
Re: Are tubular A arms available for the 92 Dakota 2wd? [Re: AtomicDog] #1430827
05/08/13 11:24 PM
05/08/13 11:24 PM
Jerseyville Il.
syco Offline
syco  Offline
Jerseyville Il.
At one time chassis tech had made them. A buddy of mine had a set and they looked/seemed to be decent. If not look up michigan metal works. He does custom/one off stuff out of plate and is quality.
