Gear reduction starter 'end head' bushing. #1430050
05/04/13 01:33 AM
05/04/13 01:33 AM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
In the process of removing the battery cable from the starter the solenoid wire stud snapped off. Not a huge problem, I found the brush and solenoid assembly is available as one complete pre-assembled unit for $35 locally. Figured I would just give the whole unit a freshen up and replace all the bushings as well. Found two of the three easily enough but I cannot locate a source for the bushing in the 'end head' portion of the starter. Per the fsm its not serviced except through replacing the part which of course isnt really possible anymore.
Someone makes it, unless all the rebuilders are totally blowing smoke and getting lucky enough to not have to replace it frequently ?
Re: Gear reduction starter 'end head' bushing. [Re: 135sohc] #1430051
05/04/13 09:58 AM
05/04/13 09:58 AM
scratchnfotraction Offline
I have a local starter/alt rebuilder that should have them.
they grind the endcap off the nose and press it into the nose housing is the way I have seen them done.
Re: Gear reduction starter 'end head' bushing. [Re: 135sohc] #1430052
05/04/13 02:33 PM
05/04/13 02:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would not waste a dime fixing the old starters. Get a new style lightweight starter and smile.
Re: Gear reduction starter 'end head' bushing. [Re: NITROUSN] #1430053
05/05/13 01:25 AM
05/05/13 01:25 AM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
I would agree but this one was atleast 'free' until I snapped the stud off and decided to give it a homebrew 'restoration'. The only reason(s) I am putting a dime into this boat anchor is because its the larger frame/faster spinning version and I know it was in decent working condition before I damaged it. Sometimes OCD gets the best of you.
