brake light switch #1428402
04/30/13 10:48 PM
04/30/13 10:48 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
im not really sure how to ask this but i was trying to diagnose why my brake lights are not working and there was a loose red wire connected wrapped with the white wire connected to the brake light switch. I accidentally grounded the red wire and it arced and now the truck has no power. does anybody know what the red wire goes to and any ideas why i have no power now
the truck is a 72 if that helps
Re: brake light switch [Re: 72d100] #1428403
05/01/13 02:08 AM
05/01/13 02:08 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You check fuses?
Re: brake light switch [Re: 76dodgeboy] #1428404
05/01/13 02:17 AM
05/01/13 02:17 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
not yet. it was getting dark so i called it quits. im not having luck with electrical lately
Re: brake light switch [Re: 72d100] #1428405
05/01/13 02:22 AM
05/01/13 02:22 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
duh i did check the fuse for stop/ hazard and it was blown. changed it and still nothing
Re: brake light switch [Re: 72d100] #1428406
05/01/13 03:39 AM
05/01/13 03:39 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
Ill check my 72 in the morning.
Sometimes when my brake lights didnt work, I wriggled the turn signal, got it back to center, and they work. Push the lever a tad up or down, and they stopped working.
I replaced the cam with one that had uncut wiring and its been working fine. It cancels back to true center. I also noticed my hazards would work but wouldn't show the left side working on the gauges. Wriggle the black square, and it works haha
I won't be able to check the truck until about 10 or so tomorrow. I'll post when I check
Re: brake light switch [Re: magnum440d100] #1428407
05/01/13 12:48 PM
05/01/13 12:48 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
no hurry. i gotta figure out why the truck has no power
Re: brake light switch [Re: 72d100] #1428408
05/01/13 12:54 PM
05/01/13 12:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the fusible link under the hood. It feeds all the power.
Re: brake light switch [Re: stumpy] #1428409
05/01/13 01:14 PM
05/01/13 01:14 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
will do. im off to work on it now. updates soon . trucks really tempting me to just put in a hotrod harness
Re: brake light switch [Re: 72d100] #1428410
05/01/13 01:28 PM
05/01/13 01:28 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
okay whatever the no power issue was was with the bulkhead connector. no the next question is what is this mystery wire thats bundled with the white brake switch wire
Re: brake light switch [Re: 72d100] #1428411
05/01/13 02:50 PM
05/01/13 02:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You should have two wires on the switch. Power in and the other to the turn signal swtch.
Re: brake light switch [Re: stumpy] #1428412
05/01/13 03:04 PM
05/01/13 03:04 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
the red wire went to the brake light switch but i just put a new bbrake light switch on and the driver brake light stays on now. maybe switch the wires on the switch around?...... nevermind i forgot the switch is always hot unless its pressed
Re: brake light switch [Re: 72d100] #1428413
05/01/13 03:47 PM
05/01/13 03:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Adjust the switch. You should have power in but not out until you push the pedal.
Re: brake light switch [Re: stumpy] #1428414
05/01/13 04:05 PM
05/01/13 04:05 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
thank you very much stumpy i do believe i have it now
Re: brake light switch [Re: 72d100] #1428415
05/01/13 06:00 PM
05/01/13 06:00 PM
woodcrest, CA
woodcrest, CA
Sorry bout the late response. Looks like you got it though.
Re: brake light switch [Re: 72d100] #1428416
05/01/13 07:30 PM
05/01/13 07:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks like the terminal of the brake switch is broken off in the pink wire terminal end.
Re: brake light switch [Re: NITROUSN] #1428417
05/01/13 08:29 PM
05/01/13 08:29 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
it was, my peanut sized brain didnt put two and two together
