magnum stroker build question #1427212
04/28/13 10:22 PM
04/28/13 10:22 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
thinking of putting a 4 inch crank in a 318 magnum,not really building it to race would just like too have the extra tourque,not a big cam or fancy heads,or anything like that,it's a 95 truck obdI,will that work?will the performance computer compensate for the bigger cubic inches or not,i have heard no that u have to upgrade too obdII,just looking for advice from someone who has already done it,thanks already
Re: magnum stroker build question [Re: bigblock4x4] #1427213
04/28/13 10:24 PM
04/28/13 10:24 PM
pana illinois
pana illinois
oh and it's a stick truck too,thanks again
Re: magnum stroker build question [Re: bigblock4x4] #1427214
05/02/13 04:37 PM
05/02/13 04:37 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Why not use a 5.9 (360) block to start off with and then add the stroker crank to it? That will really provide you with the torque you are in search of..
Re: magnum stroker build question [Re: AtomicDog] #1427215
05/02/13 07:14 PM
05/02/13 07:14 PM
pana illinois
pana illinois
i would just use a 360 and just build it if i could find one,they are scarce around here,i'm not really looking too build it for racing just for me too have fun with and maybe pi** a rustang owner or 2 off,i like scalding the tires once n a while,i'm not even sure if building a stroker would b the right way too go with my obdI computer so i may start looking for a 360 magnum engine,cause i like em
Re: magnum stroker build question [Re: bigblock4x4] #1427216
05/02/13 07:18 PM
05/02/13 07:18 PM
scratchnfotraction Offline
why not do up a 360 crank into the 318 for a 349 stoker? that might have a better chance with the computor.
Re: magnum stroker build question [Re: bigblock4x4] #1427217
05/03/13 01:08 AM
05/03/13 01:08 AM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Here is a link to a 5.9 (360) for sale on the craigslist in your general area:
http://carbondale.craigslist.org/pts/3724889081.html
Might also check the local auto salvage yards in your area for used 5.9 motors, too.
My experience has been that you can find them with a bit of patience, luck and some searching..
