Small Block dist ?
#1425101
04/24/13 10:53 PM
04/24/13 10:53 PM
Posts: 16,117 Mesa, Arizona
dart4forte
Mesa, Arizona
Anyone know where I can get the nylon sleeve (thrust collar)that is held on the shaft with a drift pin? Finally found a source. Phillbin Group out of Portland, OR. They blueprinted my tach drive distributor a few years ago. Totally forgot about them. http://philbingroup.com/about_us.htmMods.... Can we get this put into the tech library?
Re: Small Block dist ?
[Re: dart4forte]
#1425104
04/24/13 11:29 PM
04/24/13 11:29 PM
RapidRobert
I was thinking some posted an item from Menards or Lowes that was nearly identical. Might do some shopping out there & see what you see. It has a 1/2" ID EDIT If you have a parts dist you could rob the collar off of it & take this opportunity to reduce the end play to .005". www.speedwaymotors.com has a kit of washers for $5 or your ACE hardware store
