2003 5.9 starting issues #1425001
04/24/13 04:53 PM
04/24/13 04:53 PM
cumminsexpress99 Offline OP
I have had to crank a bit longer to get the '03 to start. The other day I was unable to start it after it had sat for 7 hrs. it has been rainy. I plugged it in for 2 hrs and fired right off, no hesitation, is there some sensor acting up?
I did hear the '03 have had injector issues.
Adam
Re: 2003 5.9 starting issues [Re: cumminsexpress99] #1425002
04/24/13 05:17 PM
04/24/13 05:17 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Acting up when wet, I believe points to a coil going bad. But I suppose it could be any one of the sensors that monitors cold-start conditions and tweaks the fuel table accirdingly... IAT, MAP, TPS, etc.
**Photobucket sucks**
Re: 2003 5.9 starting issues [Re: 70Cuda383] #1425003
04/24/13 05:38 PM
04/24/13 05:38 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Is this a Diesel?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 2003 5.9 starting issues [Re: Savoy1964] #1425004
04/24/13 06:09 PM
04/24/13 06:09 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Ah. It might be! He said "plug it in". I thought he meant battery charger.
If its a cummins, is the manifold heater going bad?
Re: 2003 5.9 starting issues [Re: 70Cuda383] #1425005
04/25/13 12:39 PM
04/25/13 12:39 PM
I'll check into the manifold heater
Thanks Tom
Adam
Re: 2003 5.9 starting issues [Re: cumminsexpress99] #1425006
04/25/13 01:19 PM
04/25/13 01:19 PM
Kansas
cascius Offline
cascius  Offline
Kansas
It wouldn't be happy, but it should still start in fairly cold weather without the grid heater. You might check your lift pump and see if it's working properly. These were notorious for going out because they had to work so hard to try to suck the fuel from the tank rather than push it. They were changed to an in-tank style in '05 and they sell a retrofit kit to change the '03-early '04 trucks to this style. If it's working ok then it sounds like the signs of injectors headed south.
Re: 2003 5.9 starting issues [Re: cascius] #1425007
04/26/13 12:12 PM
04/26/13 12:12 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
A Cummins will start without the heaters in 0* weather.....no extended crank....maybe a little rougher, but it will start.
Like said.....I think you have a lift pump going south, or a loose fitting or line letting air get in the fuel line and causing a drain back. I personally would go to a FASS pump/filter system if you're going to upgrade...not a fan of in-tank-pumps !!!
Get a pressure guage and watch it during the start sequence...it'll tell ya.
