Aftermarket fuel pump and regulator 1997 Ram #1424216
04/23/13 10:48 AM
04/23/13 10:48 AM
Jacksonville, AR
dmckeehan Offline OP
Jacksonville, AR
I've got a 1997 Dodge Ram 2500 4x4 used for mud racing. Looking at adding a fuel cell. 5.9 gas truck. Looking for suggestions on a suitable fuel pump and regulator to use with the fuel cell. Any help would be appreciated.
Research i have done shows that the factory setup needs about 14psi to the injectors.
Re: Aftermarket fuel pump and regulator 1997 Ram [Re: dmckeehan] #1424217
04/23/13 10:43 PM
04/23/13 10:43 PM
NW IL
Biggie Offline
Biggie  Offline
NW IL
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: Aftermarket fuel pump and regulator 1997 Ram [Re: Biggie] #1424218
04/23/13 11:01 PM
04/23/13 11:01 PM
Jacksonville, AR
Jacksonville, AR
definite possibility, my only concern is if less than 14 psi will make a big difference.
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
Re: Aftermarket fuel pump and regulator 1997 Ram [Re: dmckeehan] #1424219
04/24/13 07:57 AM
04/24/13 07:57 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
for a 1997 with the OBD-II system
the fuel pressure at the injector rail should be
38 to 48 psi
At full throttle and 5200 rpm.
Idle should be 43.5 psi or better
My memory is fuzzy but i think the FSM says
the pump volume test calls for
2 liters per minute output.
the 1992 fuel system had
an external regulator and a
second return line,
but its fuel pressure was factory set at
35 psi plus or minus 5
Re: Aftermarket fuel pump and regulator 1997 Ram [Re: 360view] #1424220
04/24/13 12:06 PM
04/24/13 12:06 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
I used a msd fi inline pump/ ls1 regulator with a return line, when i put a 97 5.9 in my 48. Works but is noisy. Ordered thru speedway motors $169.99.
48 plymouth 2 door sedan street rod
65 meyers manx dune buggy
66 coronet 500 (resto project)
77 w200 m880
02 dakota
Re: Aftermarket fuel pump and regulator 1997 Ram [Re: 66cnet500] #1424221
04/25/13 05:50 AM
04/25/13 05:50 AM
Jacksonville, AR
Jacksonville, AR
thanks guys!
