zeeker heads. #1423807
04/22/13 04:04 PM
04/22/13 04:04 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
I just bought a set of zeekers. Do they use the same head studs as Indy's? Also what intake would you run? I've seen some rb tunnel rams. Did they build a b intake? Thanks
Re: zeeker heads. [Re: wyldebill] #1423808
04/22/13 04:41 PM
04/22/13 04:41 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Zeeker was the forrunner for Indy heads,the Manley and ARP bolts work and some early Zeekers used stock head bolts.If they are max-wedge ports all the Indy Max-port intakes for low deck will work.You didn't state if they were max-wedge ports.
Re: zeeker heads. [Re: B G Racing] #1423809
04/22/13 05:48 PM
04/22/13 05:48 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I believe all the Zeeker heads were Max wedge size.The Indy intakes all work.Just have to use the RB intakes on RB engines and the Low deck intake on the 400 series no spacer's needed.
PS yes they make Tunnel Rams for the B series engines!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
