fuel pressure #1423647
04/22/13 10:31 AM
04/22/13 10:31 AM
arizona, usa
lokalik Offline OP
lokalik  Offline OP
arizona, usa
01 cummins 5spd. what should be the fuel pressure leaving the fuel filter cannister, or the pressure before the injector pump?
Re: fuel pressure [Re: lokalik] #1423648
04/22/13 07:23 PM
04/22/13 07:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It will depend on a lot of things. No less than 3 psi under load. A healthy pump should be 12 to 15 psi at idle and 10 to 12 under load. There was a tsb on pump performance. I believe it was like 40 ounces for one pump key/starter bump cycle. Volume is more important than psi.
