Magnum oil pan work on pre magnum engine? #1422789
04/20/13 09:16 PM
04/20/13 09:16 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I have an oil pan from a 98 Grand Cherokee 318 magnum in like new shape and a beat up oil pan on my 318, both rear sump of course, thought I read somewhere that the 318 magnum went to the larger 360 rear seal size, but cannot remember for sure. I'd like to use this pan on my truck 318. I know the magnum calls for a different pick-up tube, which I have, but will it bolt up? If so, any clearance issues on a mid 80's D-150? Yay or Nay?
Re: Magnum oil pan work on pre magnum engine? [Re: tt76400] #1422790
04/20/13 09:40 PM
04/20/13 09:40 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
all magnum pans use the 360 (not 273-318-340) rear arc size.
Re: Magnum oil pan work on pre magnum engine? [Re: RodStRace] #1422791
04/20/13 09:44 PM
04/20/13 09:44 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
That's what I was thinking, thanks for the confirmation! So it would work on a LA 360, could I use the magnum 1 pc gasket with this pan on an early 360?
Re: Magnum oil pan work on pre magnum engine? [Re: tt76400] #1422792
04/21/13 08:36 AM
04/21/13 08:36 AM
scratchnfotraction Offline
IIRC,this would be correct.
