18x10 rims on 2wd 2500? #1420855
04/16/13 03:17 PM
04/16/13 03:17 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Will it fit? Found a good deal on a set of 18x10 rims, came off a lifted Chevy 4x4. Not a good deal if it won't work tho. Will have to buy new tires with this deal. Any suggestions?
Re: 18x10 rims on 2wd 2500? [Re: Carsavior] #1420856
04/16/13 03:43 PM
04/16/13 03:43 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Are the 8 lug patterns the same?
The width isn't a problem. It is the back spacing that matters. I'd ask for the measurement. I have 22x10s on my lowered 2007 Ram 1500, similar to the SRT 10 wheels. They have almost 6" of backspacing. Any more than that will certainly rub. The 2500 is the same body style.
Re: 18x10 rims on 2wd 2500? [Re: Kern Dog] #1420857
04/16/13 03:46 PM
04/16/13 03:46 PM
dogdays Offline
dogdays  Offline
Bolt pattern is the same, check the center bore. If they are aftermarket wheels they'll probably fit.
Backspacing will be different, on your truck the wheels will probably stick out further.
R.
