When mini tubing #1420499
04/15/13 10:14 PM
04/15/13 10:14 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
do you cut the floor pan all the way up to the frame rail and removing the lip on it or do you leave an inch or so of lip? ive looked at a tone of pictures and cant seem to see whats going on. im thinking the frame lip gets cut off and the wheel tub goes back in all the way against the frame rail? thanks mike
Re: When mini tubing [Re: Runner] #1420500
04/15/13 10:19 PM
04/15/13 10:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
You're correct. Make the Tub flush with the frame rail.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: When mini tubing [Re: Triple Threat] #1420501
04/15/13 10:26 PM
04/15/13 10:26 PM
fresno ca
mikeysmopars Offline
fresno ca
Founder and CEO of the Central Valley Mopar Drag Pack
Re: When mini tubing [Re: Triple Threat] #1420502
04/15/13 10:27 PM
04/15/13 10:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's a personal preference I have found. Some people like to leave the lip on, most will cut it off
Alan Jones
Re: When mini tubing [Re: Runner] #1420503
04/15/13 10:47 PM
04/15/13 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cut it flush and if you want leave a lip on your tub
so you can have some metal to weld on a butt weld or
you can over lap it and seam seal the edge or weld solid
Re: When mini tubing [Re: MR_P_BODY] #1420504
04/16/13 11:02 PM
04/16/13 11:02 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
thanks guys
