Spare Tire Mounting #1419798
04/14/13 12:44 PM
04/14/13 12:44 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
My '85 Ram was purchased without a spare tire.
I can find a wheel & tire locally, no problem......but how does it mount to the under bed/frame?
Re: Spare Tire Mounting [Re: rnch] #1419799
04/14/13 02:14 PM
04/14/13 02:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
There's usually a bracket that holds it but Most remove it all together. Some trucks in the 70s had a factory in bed mount. I made my own in bed. I'll post pics tomorrow of it.
Re: Spare Tire Mounting [Re: 76dodgeboy] #1419800
04/15/13 11:19 AM
04/15/13 11:19 AM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I can find a used 15 inch rim/tire locally, no prob there.
Anyone have whatever bracket/mount I need for the spare tire?
Re: Spare Tire Mounting [Re: rnch] #1419801
04/17/13 01:09 AM
04/17/13 01:09 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
2 hooks. One is fixed, the other threaded. Along with a bar to cradle the spare tire.
Re: Spare Tire Mounting [Re: Magnum] #1419802
04/17/13 01:31 AM
04/17/13 01:31 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use a spare tire winch from a 94up
You have to bolt or weld a piece of angle between the frame rails with a piece of 2X4 bolted in the middle & 4 holes to bolt it in
I did this on a drag truck I had to move the ballast bar up & down to add or subtract weight
Re: Spare Tire Mounting [Re: 76dodgeboy] #1419803
04/23/13 04:28 PM
04/23/13 04:28 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Pics, Pls?
Re: Spare Tire Mounting [Re: rnch] #1419804
04/23/13 05:09 PM
04/23/13 05:09 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Pretty sure Dodgeconnection sells what you need. I remember this being brought up before
Re: Spare Tire Mounting [Re: 76dodgeboy] #1419805
04/23/13 05:15 PM
04/23/13 05:15 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yep they have them. your looking at just over $100 without shipping.
