yes,it is a direct bolt in 8 1/4 truck and 9 1/4 truck rear axles
just undo the u-bolts and swap the complet rear axle housing. the spring bolts and shackle can be APITA every time.
i lift the rear of the truck and use jack stands on the frame just infront of the front spring hanger to support the truck. axle at full droop.
then a floor jack to raise the axle to release tension on the leaf springs and support the axle housing while un-bolting it.
remove drive shaft, brake line from upper frame connection, shocks,u-bolts and shock plates.
with wheels still bolted to axle roll it from under the truck. roll replacment axle under truck and lift with floor jack to fit it to leaf spring center pins, install shock plates and u-bolts.
I like placing both truck tail gate to tail get with enuff room between the 2 truck to roll the axle out and swing one right then roll the other out and swing it left. then roll them under opposite trucks.
if you are doing a truck to truck swap that is.
make sure truck is high enuff to roll tires under 1/4 fender in the rear. or remove tires and handle it by hand with a buddy.
same drive shaft with the 8 1/4 and 9 1/4
