dakota rear spring hangers #1418981
04/12/13 10:29 PM
04/12/13 10:29 PM
jeff500 Offline OP
jeff500  Offline OP
Who sells the best rear spring hangers to lower a dakota 1-2 inches? I dont want to use the lowering blocks....
Re: dakota rear spring hangers [Re: jeff500] #1418982
04/12/13 10:46 PM
04/12/13 10:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Have you checked summit. I wasn't aware they make lowering hangers for them
Re: dakota rear spring hangers [Re: 76dodgeboy] #1418983
04/12/13 11:33 PM
04/12/13 11:33 PM
jeff500 Offline OP
jeff500  Offline OP
No but i will now,thanks.
Re: dakota rear spring hangers [Re: jeff500] #1418984
04/13/13 10:34 AM
04/13/13 10:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what year?
Beltech makes drop hangers. they are available on summit last I checked.
drop leafs will probably be easier though. the spring hangers are riveted to the frame, and can be a real pain to get them out.
beltech makes those as well, but the best were Hotchkis, which are no longer being made, but used sets pop up on the forums fairly regularly.
**Photobucket sucks**
Re: dakota rear spring hangers [Re: 70Cuda383] #1418985
04/14/13 10:51 AM
04/14/13 10:51 AM
jeff500 Offline OP
jeff500  Offline OP
87 dakota.
Re: dakota rear spring hangers [Re: jeff500] #1418986
04/14/13 06:52 PM
04/14/13 06:52 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
oh ok. I have no idea if the stuff from Beltech will work or not. may be worth a shot though. unless summit pulls up a listing that's actually for the 87 year trucks
Re: dakota rear spring hangers [Re: 70Cuda383] #1418987
04/14/13 08:20 PM
04/14/13 08:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Belltech 6570
Western 2011 or 201110
