'08 6.7 Runs ruff #1418926
04/12/13 08:22 PM
04/12/13 08:22 PM
West Central Indiana
Mr.Runum Offline OP
Mr.Runum  Offline OP
I have a 08 6.7 auto runs ruff/vibration when running under power, let off the accelerator and the vibration goes away. 160k miles, smarty Jr, valves ran at 150k. If it were a gas motor I would check to see if hitting on all cyls.
Any thoughts? re-check valves? broken mount?
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: '08 6.7 Runs ruff [Re: Mr.Runum] #1418927
04/12/13 09:03 PM
04/12/13 09:03 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
check your u-joints
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '08 6.7 Runs ruff [Re: 71yelladustr] #1418928
04/12/13 10:10 PM
04/12/13 10:10 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
We have a winner!! I was trying to find someone in the area that balance shafts-no one close. Had the tires balanced, but did not help. Could not get any movement out of shaft. Set brake, trany in neutral, got movement. Sometimes it takes someone from the outside, i was too close to it.
Phil
Re: '08 6.7 Runs ruff [Re: Mr.Runum] #1418929
04/13/13 03:00 PM
04/13/13 03:00 PM
Missouri U.S.A.
Missouri U.S.A.
Glad you found it.
10.02@134
