Lug stud replacement
#1418578
04/12/13 01:08 AM
04/12/13 01:08 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Have a 74 Powerwagon. Decided to drive it today to unload the stuff I had in the bed and toss some stuff in for scrap. I put some aluminum rims on and used it to plow snow this winter. Well on the way home it got a slight sake Si I pulled over to investigate. The pass front wheel had come loose and snapped a stud. It only had 4 lugnuts to start do to 5th studs threads being screwed up. So question is what's involved in replacing the studs? I plan to replace all 5
Re: Lug stud replacement
[Re: 76dodgeboy]
#1418579
04/12/13 03:28 AM
04/12/13 03:28 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
remove the old studs by cutting the "Knurelled" part off, Usually a holesaw with a 1/2" ID works for this operation. drive the out. I preferr pressing in new studs instead of pulling them in with washers and a lugnut. Less stress on the threaded portion that way.. Id install all the old studs incase the old studs have been stressed...
I am truckless..
[Re: 340SHORTY]
#1418584
04/12/13 09:07 PM
04/12/13 09:07 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
brake caliper, couple of snap rings, bearing retainer nut
No calipers on 74
[Re: 76dodgeboy]
#1418587
04/13/13 07:32 PM
04/13/13 07:32 PM
Posts: 762 Ca
76440
Ca
Same as the disc brake 80-93. The hub socket for the wheel bearing is the older style with a regular big nut...then a locking sheetmetal tab..and another nut to lock it. Easier with the proper socket but can often be done with a hammer and chisel. http://ramchargercentral.com/articles/?sa=view;article=14
