alternator over charge
#1418303
04/11/13 05:08 PM
04/11/13 05:08 PM
Posts: 32,920 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
This is driving me crazy. My charging system is running at 15+ volts. It's a two field alt and I have gone through 4 VRs and still no difference. I have a ground wire for the VR as well as a new plug. The green wire to the VR from the alt has continuity as well as power with the key on.I have battery voltage at the main alt post plus batt voltage to the other (red)field terminal. I am using a volt meter and it pulsates as do the lights. What am I doing wrong that makes the alt put out such a high voltage?
Re: alternator over charge 1983 D150
[Re: GrnMagic77]
#1418305
04/11/13 05:25 PM
04/11/13 05:25 PM
stumpy
Grand Prairie,Texas
Should I have power from the green wire with the key on and the engine not running?
[Re: stumpy]
#1418306
04/11/13 06:03 PM
04/11/13 06:03 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
yes... on mech reg, positive pole... on elect regs negative pole
[Re: RapidRobert]
#1418313
04/11/13 09:29 PM
04/11/13 09:29 PM
stumpy
Grand Prairie,Texas
Thetwo feld wires are green and red. The VR wires are red and green with green to the side and red at the top.I get no power to the top VR terminal. Looks like I am having some ignition switch issues but I will replace it tomorrow.
[Re: stumpy]
#1418315
04/11/13 09:56 PM
04/11/13 09:56 PM
RapidRobert
You might jump 12V to the "red" male alt terminal & 12V to the "top" male nub terminal on the reg & see if it straightens out
[Re: stumpy]
#1418317
04/12/13 12:50 AM
04/12/13 12:50 AM
Posts: 3,877 Oregon
hooziewhatsit
Another quick test ( ) Put your voltmeter leads on the battery+, and on the red wire* at the alternator. This voltage should be close to 0v. My bet is that it's ~.75v, or exactly the amount your voltage is above what it should be. (battery should be 14.4v. If you're seeing 15.2v, you would see 0.6v with this test. This is the culmination of all the voltage drops from the battery to the red wire at the alt) *For stock non-hacked systems, this is the blue wire.
[Re: hooziewhatsit]
#1418318
04/12/13 12:59 AM
04/12/13 12:59 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Stumpy, have you checked for full voltage to red wire at the regulator? That is what the regulator uses as a reference... If it is low the regulator will force the alternator to over charge.. As you know a marginal ground to the regulator will do the same thing... Good Luck..
[Re: hooziewhatsit]
#1418321
04/12/13 01:57 AM
04/12/13 01:57 AM
RapidRobert
I wanna do your test & just wanted to have it right
