Cylinder Cranking Pressure on Stock 426 Hemi #1417002
04/08/13 08:24 PM
04/08/13 08:24 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
What would be an anticipated cranking pressure for a stock 426 hemi with standard mechanical cam and pistons, etc.?
Al & Sheila
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417003
04/08/13 10:07 PM
04/08/13 10:07 PM
What would be a normal general (PSI) range expected on a cyl compression test on a stock Hemi
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: RapidRobert] #1417004
04/08/13 11:40 PM
04/08/13 11:40 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
That is what I was trying to figure out however I think I know it should probably be at least in the 130-140 psi range. I get 100 on all of the left bank cylinders and 85 on three of the right bank and one more cylinder at 75 psi. This is cranking with the starter motor, 3-4 revolutions. Obviously something is wrong, the engine runs but not a good idle and lot's of hesitation. It does go wide open throttle with no back firing. I am wondering where to start. I know nothing of the engine except it was supposed to be rebuilt 3k miles ago, maybe the cam is worn but there is not excessive clatter?
Al & Sheila
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417005
04/08/13 11:56 PM
04/08/13 11:56 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You've got problems, it should be well over 150, I'm thinking more like 175 or 180. Did it just start this behaviour? Timing chain jumped?
Sheldon
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417006
04/09/13 01:06 AM
04/09/13 01:06 AM
I'd do a leakdown test on it & see where the air is escaping
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417007
04/09/13 07:28 AM
04/09/13 07:28 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Are you holding the throttle wide open when cranking the motor? Squirt some oil into the cylinder and see how much higher the compression gets.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: jbc426] #1417008
04/09/13 09:49 AM
04/09/13 09:49 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I seem to recall that last time I did mine, totally stock 68 hemi w/mech cam, it was around 180psi. I had the throttle wide open and all the plugs out of the motor. I was chasing down a miss and 7 cylinders were 180 and one was 10... Busted pushrod...
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 68jim] #1417009
04/09/13 10:55 AM
04/09/13 10:55 AM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
I just got this car and the engine was supposedly rebuilt back in the mid late 90's with very little use since then. I am now wondering if the valves and seats were not hardened or set up for unleaded gas and now the valves are grinding into the seats and there is no valve lash any more. I think I will pull the covers tonight and see what I find.
Al & Sheila
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417010
04/09/13 02:46 PM
04/09/13 02:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well if it is a solid cam give it some lash 28/32 is a good start and do the compression test again.
If it is a hydraulic maybe it has way too much preload.
But I see it is solid!
I like 5 hits on compression all spark plugs out full throttle does not seem to make a big dif but they say full.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: Dodgem] #1417011
04/09/13 03:04 PM
04/09/13 03:04 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Al- I'm wondering if they backed off the valve springs while it was in hibernation. Rings? Any blow by? That sucks!
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: Dodgem] #1417012
04/09/13 03:58 PM
04/09/13 03:58 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
I took one valve cover off at lunch and there appears to be some lash but no more than .025 so do you think a few thou could make a difference? It appears a leak down test would be the best way to see what is happening?
Al & Sheila
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417013
04/09/13 04:17 PM
04/09/13 04:17 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
No .25 might be the spec for a newer cam.
Are you sure your compression gauge is correct? And I wouldn't stop cranking so fast. I let them crank until they stop climbing.
My 98 Chevy Lumina with a 3.1 and 202k miles has 180 psi just for comparison.
My 68 440 in my Satellite had about 120 psi, needed rings. I did a full rebuild. At 120 psi I don't know how many miles were on it, I'd say more than 100K but it was clean. I measured a couple of bores and came up with around .004-.006 bore taper. (they say rebore at .004, I wouldn't be afraid to re-ring it but I wanted a fresh engine for once).
Less than 100 is bad news bears. Maybe they used the wrong size rings or something, or maybe never seated them properly and glazed the bore.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: GTX MATT] #1417014
04/09/13 05:48 PM
04/09/13 05:48 PM
dogdays Offline
dogdays  Offline
You are overanalyzing the problem. No way valves are going to wear that much in a couple of thousand miles. And, if you have lash on your exhaust valves you know that isn't the problem. So it's possible your measuring technique is incorrect or that something is basically wrong with the engine, like camshaft put in wrong and bent a couple of valves.
A leakdown test like RR said would be a good place to start. And no, a couple of thousandths on the lash won't make a whole lot of difference on a compression check.
R.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417015
04/09/13 08:14 PM
04/09/13 08:14 PM
I just ran into an erroneous reading from a bad compression gauge (taking out the schrader valve (like whats in a tire valve stem) & spraying it all out with cleaner fixed it). If no leakdown tester you could use just the hose from that compression tester & if the schrader valve is in the integral fitting on the end of the hose then take it back out & if the valve is in the gauge head then screw the hose in the plug hole & connect it to shop air. Check several of the worst cyls & watch the rotor to get em at TDC & listen for where the air is escaping; carb (intake valve)/tailpipe (exhaust valve)/radiator (head gasket)/breather on valve cover(rings)
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417016
04/09/13 10:28 PM
04/09/13 10:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
now as long as it has lash it should test fine. put some oil down the cylinders to see if it is ring seal!
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: RapidRobert] #1417017
04/09/13 10:49 PM
04/09/13 10:49 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
I did use the shop air and rigged up a line with regulator and hooked up to the plug holes however it seemed the air was all going into the crankcase and it was hard to figure out if the air was going out the exhaust or elswhere. I did find what looks like bad rocker arm geometry as a couple of the adjusters were backed up into the rocker arms and the cup on the pushrod was close to or touching the rocker arm. I set the lash on all of the valves which all of them were out of adjustment and all were less than the .028 and .032.The inside of the valve covers and lifter gallery were all very clean so i think this engine was rebuilt not many miles ago. Also the cam does not have bad lobes and there are no bent push rods.
Al & Sheila
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417018
04/10/13 12:59 AM
04/10/13 12:59 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Al-my geometry was like that too. i ended up bending an exhaust valve. thus the new roller set up.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: Kirby] #1417019
04/11/13 01:02 AM
04/11/13 01:02 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
My stock compression Hemi, has 185-195 cranking pressure, with a fairly agressive hyd cam.
Yours should be 150 minn.
Might as well take it apart to see what is wrong before anything gets damaged.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417020
04/11/13 01:58 AM
04/11/13 01:58 AM
Boise
Moparteacher Offline
Boise
1st. Install a battery charger to insure constant cranking rpm.
2nd. Tie the throttle back so no fuel in the cylinders.
3rd. Use a different gauge with a different schrader valve. The wrong type of valve will give low results. A tire schrader valve used in a compression tester gives the wrong readings.
Crank each cylinder 5 times.
get back to us.
There is no sense to disassemble when a cranking compression, running compression, and leak-down will tell you what is wrong.
Re: Cylinder Cranking Pressure on Stock 426 Hemi [Re: 3twos] #1417021
04/11/13 07:04 AM
04/11/13 07:04 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I would thing anywhere from 130psi to 160psi would be considered normal.
