Re: Opinions on an addition of a helper electric fan
[Re: MidPenMopar]
#1416804
04/08/13 04:00 PM
04/08/13 04:00 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I will take a crack at this one. :-) I would think a big block car should have a 26" radiator and not a 22" which would be correct for SB or /6. This would be the first thing I would upgrade to address your cooling issue. I have heard mostly negative things about using pusher fans from "they do little to nothing" to "they hurt cooling". I have heard some say they can actually obstruct airflow through the radiator when you are cruising because they sit in front of it. At idle, it might help some, but I would not pursue this course of action. In addition, you will most likely have to upgrade the charging system to handle the extra current draw since you will want to run that fan @ idle where your alternator output is at its lowest. Also, make sure your fan shoud is well-fitted (better have one). If I were you, I'd see about going to the larger radiator first. I think a 22" radiator with a BB is a little tiny.
[Re: RapidRobert]
#1416808
04/08/13 04:20 PM
04/08/13 04:20 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I used this one on my 68 charger because I had the exact overheating problem at idle plus my A/C would stop blowing cold at idle. Installing this fan solved both issues. http://www.the-fan-man.com/shop/size-pus...316f4ddd4b70a22But you may have to upgrade your alt. I have it wired to come on automatically with the a/c or if the temp goes over 175.
[Re: 70Duster440]
#1416810
04/08/13 04:46 PM
04/08/13 04:46 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Fan shroud? That can make all the difference. I cooled my 440 with a 22" 3 row, shroud, and solid fan.
Yep i have a nice factory shroud and the fan is about 2 inches away from it.
[Re: MidPenMopar]
#1416811
04/08/13 04:56 PM
04/08/13 04:56 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
So far I have had the stock 22 inch recently radiator flushed out and cleaned. I am running straight distilled water and some soluble oil as an additive. I also installed a higher output water pump and am running a stock clutch fan.
Do you have a stock fan shroud on it?
Could also have to do with the carb tune and timing curve/events of the motor.
[Re: MidPenMopar]
#1416812
04/08/13 04:58 PM
04/08/13 04:58 PM
RapidRobert
I believe you want the fan to be ~2/3 of the way into the shroud. Can someone clarify
[Re: MidPenMopar]
#1416813
04/08/13 04:59 PM
04/08/13 04:59 PM
autoxcuda
So Cal
What is the amound the fan is sunk into the fan shroud opening? Like 50/50 in and out. Or something else?
What is the minimum gap between the fan tip and shroud edge? Probably not 100% perfect consistant gap all the way around and that's fine.
[Re: RapidRobert]
#1416814
04/08/13 05:01 PM
04/08/13 05:01 PM
autoxcuda
So Cal
50/50. Half in and half out.
[Re: 62maxwgn]
#1416816
04/08/13 05:09 PM
04/08/13 05:09 PM
cjskotni
North Carolina
Straight water is not the best coolant !
Straight water will transfer heat better than anti-freeze or the water/anti-freeze mix.
However, your boiling point is not going to be near as high as with coolant added so always a danger of boiling the coolant which could blow a hose!
[Re: cjskotni]
#1416818
04/08/13 05:27 PM
04/08/13 05:27 PM
autoxcuda
So Cal
[Re: dOc !]
#1416820
04/08/13 05:38 PM
04/08/13 05:38 PM
RapidRobert
OT, On the (warm weather only) stock car: straight water & a can of water pump lube & antirust & some water wetter or several drops of dish soap
[Re: autoxcuda]
#1416821
04/08/13 05:46 PM
04/08/13 05:46 PM
MidPenMopar
So is that the definate answer for fan placement as i have always wondered what was the best. I thought as close to the radiator as possible, but it seems not.
[Re: RapidRobert]
#1416822
04/08/13 05:49 PM
04/08/13 05:49 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
My 65 440 that built large runs a stock never touched rad.Its a C body 22 with factory shroud.I run a SS 18 inch flex fan.Never overheats even at the track and idling in the 90s.When I street drive in the 80s,90s it still never goes over 190.My kids 62 300 built 413 also runs a 22 factory.It runs like mine never over 190.His was recored to a 4 row about 12 years ago.Rocky
Chrysler Firepower
