#14161 - 01/23/05 05:35 PM Oil slinger installation w/ timing chain tensioner
64Belvedere Offline
super street
Loc: Kansas
Has anyone installed the crank mounted oil slinger disk along with the Mopar timing chain tensioner? On my poly 318, the disk rubs on the tensioner arm.
I'm assuming I can just leave the disk out? Will I have an increased chance of leaks at the front seal with the disk not installed?
[image][/image]
#14162 - 01/23/05 06:07 PM Re: Oil slinger installation w/ timing chain tensioner [Re: 64Belvedere]
earlybee Offline
Loc: Arlington, Texas
looks like that won,t work. if the balancer snout is perfect you should be ok without it. if you have a hydraulic supply store close they might have better double lip seal than your stock one. good luck
#14163 - 01/23/05 06:33 PM Re: Oil slinger installation w/ timing chain tensi [Re: 64Belvedere]
64Belvedere Offline
super street
Loc: Kansas
***** FIXED!! *****
After looking at the tensioner arm, I figured out a solution. I trimmed a small notch into the bottom of the arm and got the clearance I needed. Super easy.
[image][/image]
#14164 - 01/23/05 06:36 PM Re: Oil slinger installation w/ timing chain tensi [Re: 64Belvedere]
MoparforLife Offline
Loc: Upper Midwest
Are you afraid of you seal leaking or what. That is the reason for the slinger - not to oil the chain but to keep excessive oil from the front seal. New seal materials rarly leak without it and they were only installed intermittantly OEM. Some did and some didn't.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
#14165 - 01/24/05 05:36 AM Re: Oil slinger installation w/ timing chain tensi [Re: MoparforLife]
64Belvedere Offline
super street
Loc: Kansas
Leaks at the front seal was my main concern. I know installing it is no guaranty against leaks, but it couldn't hurt.
[image][/image]
25,493 Registered Members
193,100 Topics
Holley metering blocks
by Old School
09/24/18 01:17 PM
Can anyone point me to fluid flow schematics for 727?
by BradH
09/24/18 01:07 PM
73 Barracuda Creature Comforts issue
by BcudaChris
09/24/18 12:47 PM
3 speed column shift > A904 automatic swap - Linkages
by dart_73_br
09/24/18 10:49 AM
