Oil slinger installation w/ timing chain tensioner
#14161
01/23/05 08:35 PM
01/23/05 08:35 PM
Posts: 845 Kansas
64Belvedere
super street
super street
Kansas
Has anyone installed the crank mounted oil slinger disk along with the Mopar timing chain tensioner? On my poly 318, the disk rubs on the tensioner arm. I'm assuming I can just leave the disk out? Will I have an increased chance of leaks at the front seal with the disk not installed?
[image][/image]
Re: Oil slinger installation w/ timing chain tensi
[Re: 64Belvedere]
#14164
01/23/05 09:36 PM
01/23/05 09:36 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Are you afraid of you seal leaking or what. That is the reason for the slinger - not to oil the chain but to keep excessive oil from the front seal. New seal materials rarly leak without it and they were only installed intermittantly OEM. Some did and some didn't.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
