Oil slinger installation w/ timing chain tensioner #14161
01/23/05 08:35 PM
01/23/05 08:35 PM
Kansas
64Belvedere Offline OP
super street
super street
Kansas
Has anyone installed the crank mounted oil slinger disk along with the Mopar timing chain tensioner? On my poly 318, the disk rubs on the tensioner arm.
I'm assuming I can just leave the disk out? Will I have an increased chance of leaks at the front seal with the disk not installed?
[image][/image]
Re: Oil slinger installation w/ timing chain tensioner [Re: 64Belvedere] #14162
01/23/05 09:07 PM
01/23/05 09:07 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
looks like that won,t work. if the balancer snout is perfect you should be ok without it. if you have a hydraulic supply store close they might have better double lip seal than your stock one. good luck
Re: Oil slinger installation w/ timing chain tensi [Re: 64Belvedere] #14163
01/23/05 09:33 PM
01/23/05 09:33 PM
Kansas
super street
super street
Kansas
***** FIXED!! *****
After looking at the tensioner arm, I figured out a solution. I trimmed a small notch into the bottom of the arm and got the clearance I needed. Super easy.
[image][/image]
Re: Oil slinger installation w/ timing chain tensi [Re: 64Belvedere] #14164
01/23/05 09:36 PM
01/23/05 09:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you afraid of you seal leaking or what. That is the reason for the slinger - not to oil the chain but to keep excessive oil from the front seal. New seal materials rarly leak without it and they were only installed intermittantly OEM. Some did and some didn't.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Oil slinger installation w/ timing chain tensi [Re: MoparforLife] #14165
01/24/05 08:36 AM
01/24/05 08:36 AM
Kansas
super street
super street
Kansas
Leaks at the front seal was my main concern. I know installing it is no guaranty against leaks, but it couldn't hurt.
[image][/image]
