Re: 89 Ram has no acceleration!
[Re: herkamer]
#1415918
04/08/13 10:18 PM
04/08/13 10:18 PM
Posts: 15,487 Florida
scratchnfotraction
There are no long or short flashes, just long or short pauses.
12 - PCM Power loss within 50 last key ons. To be expected since the battery has been out
13 - MAP sensor problem - Controls most fueling, that would certainly be something to look at
22 - Coolant temp too high or low
31 - Problem with canister purge solenoid circuit
Based on your description I get 34 34 - Open/short in speed control vacuum or vent solenoid circuits
55 - End of codes
Almost everyone in the world has a cell phone with video camera. Maybe take a video?
I will wager the MAP sensor is bad.
this tells the PCM how much air is moving thru throttle body by reading "manifold absolute pressure" IIRC. or mass air flow?
crappy stock electronic junk, strip it for a carb and points dist and never fool with it again.
[Re: newportrider]
#1415922
04/09/13 10:07 PM
04/09/13 10:07 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
and check the wires going into the map. we had a Dynasty that was coming up bad map, changed it, stil had the problem. found out one of the wires going into the plug was bad, and when the engine rocked it was sending out a false code.
1981 Dodge D150 360 auto
[Re: RoadRunnerLuva]
#1415926
04/12/13 12:39 AM
04/12/13 12:39 AM
Posts: 905 SD
zrxkawboy
SD
Several possibilities...good suggestions here, but don't shotgun it! Diagnose it! Start by testing fuel pressure.
It's Swifty! Swifty, you toad sucker!
