Will "Metal_Fill" body filler stand up to heat? #1415849
04/07/13 10:49 AM
04/07/13 10:49 AM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
I have a set of old M/T valve covers. Like the ones in the picture. I would like to get rid of the fins and M/T, and smooth them out to match the raised "inscription pad" at the bottom, for a custom look. I had thought about having them machined down but that would go into the recess underneath the raised pad.
Is there something I can fill in the area between the fins with? Too deep to want to use normal body filler obviously. I found "Metal Fill" supposedly cures hard enough to drill and tap, Bondo also has a metal filler. I am just wondering if whatever polymer base is in them will stand up to the heat that valve covers will being seeing on a street driven car.
Thanks all.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Will "Metal_Fill" body filler stand up to heat? [Re: Michael Ecks] #1415850
04/07/13 12:03 PM
04/07/13 12:03 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
I know that if you use All Metal they say you can powdercoat over it if you use extra hardner in it so it should hold up to the heat.
Re: Will "Metal_Fill" body filler stand up to heat? [Re: azblackhemi] #1415851
04/07/13 12:15 PM
04/07/13 12:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
THis is what we used to use the the Navy for repair aluminum castings regardless.
http://www.devcon.com/products/products.cfm?brand=Devcon&family=Aluminum%20Putty%20%28F%29
Does NOT look like aluminum when cured and it will not polish out. Dunno if you can powder coat over it either.
According to the MSDS information "Heating resin above 300 F in the presence of air may cause slow oxidative decomposition." so it may not be best.
Don't be the exception.
Re: Will "Metal_Fill" body filler stand up to heat? [Re: Michael Ecks] #1415852
04/08/13 10:31 AM
04/08/13 10:31 AM
Jacksonville Florida
elitecustombody Offline
Mill the fins off and weld the holes
Re: Will "Metal_Fill" body filler stand up to heat? [Re: elitecustombody] #1415853
04/08/13 02:19 PM
04/08/13 02:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'd just sell them and buy a set that are smooth.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Will "Metal_Fill" body filler stand up to heat? [Re: Silver70] #1415854
04/09/13 12:44 AM
04/09/13 12:44 AM
Columbus, GA
Columbus, GA
I've done a lot of looking and no one makes a set that I like. Summit has a very nice looking smooth top cast valve cover for cheap...too bad it is only for big blocks. Thought about fabricated ones, but I don't care for the weld lines on them. I'll probably end up trying the All-Metal and see how it goes.
Re: Will "Metal_Fill" body filler stand up to heat? [Re: Michael Ecks] #1415855
04/09/13 08:25 AM
04/09/13 08:25 AM
London, England
Gavin Offline
Gavin  Offline
London, England
This has been done for SB, just not 100% sure about the make of covers. IIRC the finned MP covers can be milled down for a smooth look.
Again IIRC member LAR414 had milled ali covers which thus looked somewhat stock once painted. My memory could be wrong on the specifics (though not the fact it has been successfully done with the right covers) but FWIW......
Re: Will "Metal_Fill" body filler stand up to heat? [Re: Michael Ecks] #1415856
04/09/13 01:34 PM
04/09/13 01:34 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
get fab ones and sand/grind the welds smooth, or as stated elsewhere, the MP ones can be milled smooth...that's what LAR414 has IIRC on his dart
2017 Grand Cherokee Overland
