95 dakota 6 lug to 5 lug? #1415681
04/07/13 01:08 AM
04/07/13 01:08 AM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
What do I need to do to change the bolt pattern to 5x4.5 from a earlier dakota. can I just change the rotor? the truck has a 8 1/4 rear I will change the axle.
thanks
Re: 95 dakota 6 lug to 5 lug? [Re: kams] #1415682
04/07/13 08:49 AM
04/07/13 08:49 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've not done it myself, but that sounds like a good place to start. the early dakota's came with 5 or 6 lug bolt patterns.
**Photobucket sucks**
Re: 95 dakota 6 lug to 5 lug? [Re: kams] #1415683
04/07/13 09:37 AM
04/07/13 09:37 AM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
With that year. It is just as simple as changing the front rotors and the axles.
Re: 95 dakota 6 lug to 5 lug? [Re: kams] #1415684
04/14/13 11:11 PM
04/14/13 11:11 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
use the first yr dak brake rotors, they are 5 lug
Re: 95 dakota 6 lug to 5 lug? [Re: Dakota_Don] #1415685
04/14/13 11:30 PM
04/14/13 11:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
87-89 or 90 is 5 lug.
Re: 95 dakota 6 lug to 5 lug? [Re: 76dodgeboy] #1415686
04/16/13 12:40 AM
04/16/13 12:40 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
90 was the last year for the 5 lug Dakotas. You can just swap the rotors up until the end of 96. The 97 & up have the new style bearings and different spindles. Gene
