First gen dakota nose swap. #1414906
04/05/13 02:59 PM
04/05/13 02:59 PM
Indiana, PA
moparjim87 Offline OP
Indiana, PA
Has anyone done it? I have a 95 club cab dakota, and I have an 88 dakota that id like to put its clip on the 95. Being their both "first gens", how hard could it be? Both trucks are complete and are in decent shape. Thanks
Re: First gen dakota nose swap. [Re: moparjim87] #1414907
04/05/13 03:56 PM
04/05/13 03:56 PM
Two Harbors, MN
chrgr340 Offline
chrgr340  Offline
Two Harbors, MN
I know the fenders are the same. I think you'll just need to change the radiator support, bumper, grille, headlights, and hood. I plan to eventually do this to the '87 I have also.
1972 Dodge Charger - F7, Rallye pkg, 340, A833
2007 Dodge Charger R/T R&T - 12sec daily beater
1999 Dodge Dakota R/T - M1, cam, heads, T56 swap
1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
Re: First gen dakota nose swap. [Re: chrgr340] #1414908
04/06/13 01:14 AM
04/06/13 01:14 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
chgr 340 is right on--- but you will need to cut the frame extension off a later truck so the radiator support bolts and bumper bolts are properly located---my son and i did this to an 87 used as a rock crawler---then it gives you room for a V8....bob
Re: First gen dakota nose swap. [Re: moparjim87] #1414909
04/14/13 11:15 PM
04/14/13 11:15 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
isnt the 95 dak longer in the front then the 88?
