Re: throttle/kickdown bracket [Re: redraptor] #1414158
04/04/13 10:32 PM
04/04/13 10:32 PM
scratchnfotraction Offline
I could never shoot this guy.
RIP Dutch
Dutch looked like a cute guy. Having a throttle bracket from a cruise control vehicle can help with the hi-rise intake.
yea,he was one of the best.
the cruz control extention clamp is exactly what I used to raise mine with.
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414159
04/24/13 06:08 PM
04/24/13 06:08 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i have another qustion. is the mancini kit the same as the bouchillion?
Re: throttle/kickdown bracket [Re: 72d100] #1414160
04/25/13 01:37 PM
04/25/13 01:37 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Yes, they just add their own prefix to the BPE part number.
Re: throttle/kickdown bracket [Re: 135sohc] #1414161
04/25/13 03:35 PM
04/25/13 03:35 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I am using the Mancini tall bracket which puts the throttle cable on a more even plane with the carb lever.
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414162
04/25/13 03:36 PM
04/25/13 03:36 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Bracket
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414163
05/01/13 09:48 PM
05/01/13 09:48 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
I ended up using the ar tall throttle bracket and it works almost perfect. yes i know my kickdown is upside down.will work even better when i put a carb spacer on it
Re: throttle/kickdown bracket [Re: 72d100] #1414164
05/02/13 12:56 AM
05/02/13 12:56 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Exactly as I am using a spacer too and it is good to go. Glad it worked out for you. I did; however install a longer linkage adjustment piece that allowed me to dial in the up and kickdown shift points.
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414165
05/02/13 01:09 AM
05/02/13 01:09 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
where did you get the longer adjustment piece?
Re: throttle/kickdown bracket [Re: 72d100] #1414166
05/02/13 09:16 AM
05/02/13 09:16 AM
yep,looks like I will be going with that bracket to ditch the hoky cruz control clamp I am using. close but cant get 100% full throttle with it.
where did you get the extention and would you post a pic of it on your carb/intake?
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414167
05/02/13 10:31 AM
05/02/13 10:31 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I bought it off of EBAY I think the seller's handle was torqueflite patty. I looked on EBAY last night but couldn't find it but I'll look again. I'll run out and take a pix of my setup and post it this AM
Don't know if he is in business anymore but here is his info:
Pat Blais Transmissions
12050 15th Ave NE, Seattle, WA 98125
(206) 365-1966
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414168
05/02/13 10:57 AM
05/02/13 10:57 AM
thank you,
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414169
05/02/13 11:00 AM
05/02/13 11:00 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Pix of the longer kickdown adjuster
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414170
05/02/13 11:02 AM
05/02/13 11:02 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Side view of my setup
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414171
05/02/13 11:03 AM
05/02/13 11:03 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
One more
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414172
05/02/13 11:18 AM
05/02/13 11:18 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414173
05/02/13 11:20 AM
05/02/13 11:20 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I used the previous Edelbrock adjuster years ago when I swapped to a taller manifold. They just screw on to end of your adjustment rod then the adjuster screws on to it.
BTW, Summit Racing has both sizes in stock 1/4" and the 5/16" for $7.95
Re: throttle/kickdown bracket [Re: Hemi_Ram] #1414174
05/02/13 11:50 PM
05/02/13 11:50 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
That looks like an allthread union nut and a short stud in one end...about 75 cents at your local bolt store. I know fastenall carries the union nuts.....
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: throttle/kickdown bracket [Re: old_goat] #1414175
05/03/13 02:02 AM
05/03/13 02:02 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
That would be great for that price
