Page 3 of 3 1 2 3
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412183
04/15/13 12:05 AM
04/15/13 12:05 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
I don't have the funds right now for an aftermarket floor shifter for the truck. Soooo, I used the stock 833od shifter handle, some 16 gauge sheet metal,, and some 3/16x1" strap steel, along with a few swivel linkage pieces I had, and made my own automatic floor shifter. The linkage rod itself is 5/16 pencil rod.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412184
04/15/13 12:07 AM
04/15/13 12:07 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Another view showing pc of strap welded to bottom of handle....
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412185
04/15/13 12:09 AM
04/15/13 12:09 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Here is what it looks like dummied up to the floor shifter hump and boot...
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412186
04/15/13 12:14 AM
04/15/13 12:14 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Worm's eye view all hooked up. It shifts smooth as glass. I do plan on making up a reverse lock out.
Total investment: $6.00! And 2 hours of my time.
To right is the end that is hooked to 727 linkage arm.
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: dodgedakotaman] #1412187
04/15/13 12:25 AM
04/15/13 12:25 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks Dakotaman!
I have a lot of time and a fair amount of $ in it, and nowhere near done yet. In the near future it will get an aluminum radiator, an interior redo, and a lot of sheetmetal work with a fresh coat of black suede....amongst other things.
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412188
04/15/13 01:03 AM
04/15/13 01:03 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Great job; the frame cutout looks similar to mine.
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412189
04/15/13 10:07 PM
04/15/13 10:07 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Looking Good Bill
Re: Today, I am saying goodbye to my little leaning friend. [Re: Webster] #1412190
04/16/13 02:52 PM
04/16/13 02:52 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks Webster!
I am still working out the bugs, like a slight coolant leak from around 2 of the header bolts. At first I thought it was coming from head bolts!
I am going to change radiators, because it was running warmer than I wanted it to. I found a 3 row aluminum replacement with tranny cooler for less than 200 bucks.
The problem was the one I had in there wasn't flowing near the coolant it should.
I will get there. Glad I am somewhat patient.
Other than a few very minor things, I am very happy!
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412191
04/17/13 10:51 PM
04/17/13 10:51 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Got all the leaks fixed. Just waiting on the radiator now.
I ordered a double pass from speedway motors...
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412192
05/02/13 11:59 PM
05/02/13 11:59 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Radiator installed with a fabbed by me top shroud made of stainless steel sheet. I am using 2 pusher electric fans with a 160 degree switch. Also have a manual override switch.
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412193
05/03/13 12:01 AM
05/03/13 12:01 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Another view....
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412194
05/03/13 03:00 AM
05/03/13 03:00 AM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
I still can't believe you offed the slanty! I guess the tables have turned, now - I get approaching 30 MPG - you'll be getting maybe 10, with the 3.91s...
Looking good, Bill - very creative little doodads, but do you see a clean up in the truck's future??
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412195
05/03/13 12:56 PM
05/03/13 12:56 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looking good. i like seeing stuff actually get finished. collecting parts for mine, with the hopes it will be done before summer....
Re: Today, I am saying goodbye to my little leaning friend. [Re: Golden-Arm] #1412196
05/03/13 09:20 PM
05/03/13 09:20 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Well Wagonmaster, there is a clean up in the future. I know, it was dirty in the pic. Fresh coat of black suede and an interior redo soon. The fuel mileage issue, work provides me fuel.
As for the little leaner, it is a cast crank engine, but I do just happen to have a freshly bored .030 over steel crank block, and a good standard/standard crank. I bought the 7.5:1 pistons a few years back when the machine work was done. I am going to use the head with oversize stainless valves from the truck engine with a new 280 cam.
A turbo and efi is in its future...it will be backed with a 833od. Its new home will be a different twist on a roadster.
Thanks golden arm, I am nowhere near done with the truck.
84 D150 440/727
79 /6 swb D150
Re: Today, I am saying goodbye to my little leaning friend. [Re: old_goat] #1412197
05/03/13 09:22 PM
05/03/13 09:22 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Also golden arm, keep plugging along, you will get it done.
Good luck on your project!
84 D150 440/727
79 /6 swb D150
Page 3 of 3 1 2 3
