Dodge Ram 1500 spare tire question #1411835
03/30/13 11:03 PM
03/30/13 11:03 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I just noticed i have a 17 inch spare tire on my 2003 Ram 4x4 1500 but i have the 20 inch upgraded rim package. So does it do harm to the drivetrain to run the 17 spare if i need to in an emergency??
Stu
Re: Dodge Ram 1500 spare tire question [Re: MidPenMopar] #1411836
03/31/13 12:11 AM
03/31/13 12:11 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Most of the time no. The factory commonly used a smaller rim and a tire that was still the same OD as the 4 on the road so it would be safe to use. If you have a different OD spare vs the tires OD on the truck the LS rear diff could get a bad work out.
Re: Dodge Ram 1500 spare tire question [Re: NITROUSN] #1411837
03/31/13 12:55 AM
03/31/13 12:55 AM
That's what i was thinking as i remember years ago being told never run a different size of height tires even for a short distance on the rear axle.
Is that true for the fronts as well?? I know with hand locking hubs you could do that but what about these on the automatic locking hubs??
Re: Dodge Ram 1500 spare tire question [Re: MidPenMopar] #1411838
03/31/13 02:26 AM
03/31/13 02:26 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
As long as you never put it in 4WD, it shouldn't cause the front diff any problem as the auto hubs would be disengaged in 2WD. If you have an open rear diff it would sure give the spider gears some exercise but for a short distance at reduced speeds likely be OK. The clutches in a suregrip rear diff would be up in smoke in pretty short order IMHO.
Kevin
Re: Dodge Ram 1500 spare tire question [Re: Twostick] #1411839
03/31/13 11:11 AM
03/31/13 11:11 AM
Kevin
I replaced the stock factory locking differntal with an Aurburn locking unit a few years ago. So i guess if i had to put on the spare it would only be on the front that i could do it, correct??
Re: Dodge Ram 1500 spare tire question [Re: MidPenMopar] #1411840
03/31/13 11:25 AM
03/31/13 11:25 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not if the outer diameter is close to the bigger rims, then you're okay.
Re: Dodge Ram 1500 spare tire question [Re: buildanother] #1411841
03/31/13 11:29 AM
03/31/13 11:29 AM
Good idea, i will go measure later and see.
