Re: Bulkhead wiring cleaner. Wire brushes and...?
[Re: Kern Dog]
#1410363
03/28/13 04:25 PM
03/28/13 04:25 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Hello again. I'm rewiring the underhood harness on the Charger and I will be cleaning both sides of the firewall bulkhead connector. I need to know what you suggest for cleaning the contact points. I used a wire brush but I have yet to get the copper looking shiny as new. There are no damaged or pitted connectors, but I figured that now is the time to get it as clean as possible. Thanks, Greg
I have always used this stuff but then again, I spent my high school and college years working in TV repair. Will not tarnish copper or plated stuff and leaves a light coating to prevent further oxidation. http://www.radioshack.com/product/index.jsp?productId=12784986 I also pack the connectors with CRC Dielectric Grease to keep water out.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: RSNOMO]
#1410366
03/28/13 05:11 PM
03/28/13 05:11 PM
Posts: 416 Franklin Co. Illinois
runinonmt
Lime Away. No need to remove the connectors. Pour it in,let it soak a while,rinse with water,blow dry,coat with dielectric grease,assemble. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Kern Dog]
#1410370
03/28/13 10:25 PM
03/28/13 10:25 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
$16 for an 8 oz can.
Key-Rhyst...
That's caviar price...
[Re: RapidRobert]
#1410371
03/29/13 01:44 AM
03/29/13 01:44 AM
Posts: 18,677 Fresno, CA
Jim_Lusk
Fresno, CA
My concern was mostly with the firewall mounted female side. I bought a can of DeOxit spray.
Those are the ones I'd replace as they are so hard to clean . Holler how that spray works
They are hard to clean, but aren't hard to get right. The loops usually need to be tightened...
[Re: RapidRobert]
#1410373
03/29/13 03:22 AM
03/29/13 03:22 AM
Jim_Lusk
Fresno, CA
Jim will that make the male ends scrape em down to clean brass when they go together?
Yes, to some degree. I did this to my old 67 Barracuda fastback shortly after I bought it and never had another bulkhead related problem. My niece had an 89-ish GM FWD with the 3.3 V6 and it developed a problem with the connector on the ignition module. Same fix...
[Re: Jim_Lusk]
#1410374
03/29/13 04:33 AM
03/29/13 04:33 AM
Posts: 243 Helsinki, Finland
Anselmi
Helsinki, Finland
Has anyone used RPM (Rust Prevention Magic) to protect the connectors after cleaning them?
'66 Plymouth '64 Dodge '63 Plymouth x 3
[Re: Kern Dog]
#1410375
03/29/13 05:50 AM
03/29/13 05:50 AM
Posts: 122 St. Paul, Mn.
Jim_S
St. Paul, Mn.
I replaced all of them on my 69 Roadrunner with the exception of the ammeter contacts which were converted to straight 10 gauge wires through the bulkhead. I crimped and soldered each one. Napa 725145 for the female and 725147 for the male which are a little more heavy duty than original. Dielectric grease on reassembly.........
69 Roadrunner 383 stock
[Re: hp383]
#1410376
03/29/13 09:58 AM
03/29/13 09:58 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
I'm not sure about the toilet cleaner, wouldn't that possibly be too corrosive?
You don't leave them in there for a long time , or over night. soak for a few minutes , scrub with a plastic brush and rinse in water. For the stuff you get to use at home might take a little more effort?
But the white vinegar mentioned after I posted sounds like a good alternative , it's not sure acidic , I'll have to give it a try .
[Re: Anselmi]
#1410377
03/29/13 10:00 AM
03/29/13 10:00 AM
JohnRR
U.S.S.A.
Use electric dielectric grease , if the factory used that on them way back then you wouldn't see half the oxidation issues , some car makers use it now .
[Re: Kern Dog]
#1410381
03/30/13 01:24 AM
03/30/13 01:24 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: Kern Dog]
#1410383
03/30/13 07:22 AM
03/30/13 07:22 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Some info on the dielectric grease: http://www.wisegeek.org/what-is-dielectric-grease.htmYou can apply generously to the "pockets" in the connectors, the grease is not conductive, and is designed to prevent oxygen, and moister, from corroding or tarnishing the contacts. However I think the author of the page may not be a "car" guy: Quote:
Dielectric grease is widely used as a sealant for spark plugs in gasoline or diesel engines, as well as on the gaskets of multi-pin connectors in the electrical systems of vehicles and boats.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
