91 D44 intermediate shaft seal question. #1409946
03/27/13 10:19 PM
03/27/13 10:19 PM
Albion NY
Haibach Boys Offline OP
Albion NY
im rebuilding the front axle on my w150, ball joints, new outer axles, wheel bearings, blah blah, now i wanta change the intermediate shaft seal in the housing, its on the drivers side of the Cad box. how the heck do i get it out and install it??? if the pic loads the one labeled "Seal"
Re: 91 D44 intermediate shaft seal question. [Re: Haibach Boys] #1409947
03/27/13 11:49 PM
03/27/13 11:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'm sure the dealers had a special tool for that, but I made my own out of a 2 foot 3/8" threaded rod and some combination of washers and old bearing races or something. It was a pain, and a while ago.
Re: 91 D44 intermediate shaft seal question. [Re: Haibach Boys] #1409948
03/28/13 09:42 PM
03/28/13 09:42 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Pull the cad hosuing and fork, then the collar, knock the seal out after the axle shaft is out, pull old seal out and put new seal in on driving mandrel and use threaded rod to pull in. Use only a oem mopar or timken seal (or in pick skf). Do not use a National seal- they got the dimensions wrong
Can buy this, but he sells just the mandrels also and get the threaded rod/nuts/washers at the hardware store. Mandrels keep it straight. Hard to navigate his site now since he screwed it up...
http://www.quad4x4.com/cgi-bin/commerce.cgi?preadd=acton&key=884620
Limited pics of how I did it here, 3/4 way down page
http://ramchargercentral.com/mopar-trucks/1999-w250-project/
